586,103 active members*
3,446 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Yaskawa Varispeed 626VM3 Help
Page 3 of 3 123
Results 41 to 45 of 45
  1. #41
    15362
    Re: Yaskawa Varispeed 626VM3 Help
    Quote Originally Posted by ggtech View Post
    Mine is now fixed. Measure your thermistor before doing anything. Mine turned out to be working. It should show some resistance. Blast it with cold air from a computer cleaner can, it should change.
    In my case it ended up being a bad trace on the board going from the the ribbon connector to a capacitor on the board. Had to take it to a repair shop and it took the technician some time to find the fault. He ran a wire between the 2 points.hope this info helps others.
    So had the cap damaged the trace, this can be a common problem, capacitors should be changed every 5 years in these drives, if you have the manual, it will tell you to do this to prevent damage to the boards.
    Mactec54
  2. #42
    Sep 2021
    You would not wire the pot to anything, to do with the thermistor
    heatsink thermistor 25.53 ohms - temperature reading V1-13 -28.0 C
    Motor thermistor 7.5 ohms - temperature reading V1-12 25.2 C
    any way to trick the input with a Pot to get a reading 0f 7.5 ohms for the heatsink
  3. #43
    Do you have photos of the bridge I made?
  4. #44
    Hello Guyz!
    Quote Originally Posted by ennab1977 View Post
    I have the same problem
    but what you mean by a power supply problem ?!
    is it control power supply
    or power interface card power (fuses & transformers are working properly )
    and starting the drive (not installed in the machine) by supplying 3 phase 220 VAC with an electrical contactor and contected to an encoder to avoid encoder problem !!
    power supply control output of the power supply as follow at 24 CN
    1. Ground
    2. Ground
    3. 5 VDC
    4. 5 VDC
    5. 15 VDC
    6. -15 VDC
    7. 24 VDC
    8. 5 VDC
    Any suggestions !!!!???
    Can anybody else confirm this pinout?
    By my power supply I cannot measure any voltage by the output connector, so it seems to be broken. I found a replace part with the following rated current output:
    5V / 15A
    24V / 2.7A
    15V / 2A
    -15V / 2A
    What do you think, is this enough?
    Gábor
  5. #45
    Quote Originally Posted by prabhs98 View Post
    Hello,
    I am having a Yaskawa Spindle Drive Varispeed 626VM3 is having Alarm F-E04. It means Motor Code Setting Error. I am unable to resolve it. If you know any solution please tell me. Can you please tell which parameter of this drive is responsible for Drive Capacity Code.
    Prabhsimran Singh
    Have you resolved this issue? I am currently receiving the error F-E02 and I need assistance on how to resolve it. Based on the manual, the source of the issue is Data in memory (NVRAM) exceeded upper or Lower limit. There is a parameter C2-01 that shows as higher than upper limit, but the drive will not allow me to change this parameter. Any suggestions?
Page 3 of 3 123
  1. yaskawa varispeed 626vm3.
    By wilko1 in forum Servo Motors / Drives
    Last Post: 10-23-2019, 01:42 AM
  2. matsuura cnc with Yansac varispeed 626vm3 strange problem
    By ivision in forum Servo Motors / Drives
    Last Post: 03-30-2014, 07:56 PM
  3. Trouble Varispeed 626vm3
    By Fyp Engineering in forum Servo Motors / Drives
    Last Post: 06-17-2013, 11:49 PM
  4. yaskawa 626 varispeed
    By george9 in forum DNC Problems and Solutions
    Last Post: 10-15-2010, 12:45 AM
  5. Yaskawa Varispeed 626 MT
    By bradodarb in forum Phase Converters
    Last Post: 04-27-2009, 02:38 PM
