587,467 active members*
4,763 visitors online*
    Jun 2012
    125
    Bridgeport 2J head rebuild
    I am working on a rebuild for a 2J head. The operator complained about noise and vibration. After pulling the head and opening it up it is full of green plastic. Is there a rebuild kit for this that contains the necessary items?
    Mar 2012
    378
    I don't know what that is, but you can get rebuild kits from H&W Machine Repair and they are very knowledgeable and can probably answer your question. Bought my ball screws and some other BP parts from them recently and found them a great company to deal with. H&W - Parts for Bridgeport Mills, New & Used Machinery, DRO's, Power Feeds
    Jun 2012
    125
    Thanks this is what i needed 2hp Adjustable Motor Vari-Disc Assembly
    Nov 2004
    3028
    A heads up. The original heads were 1.5 HP and later they became 2 HP. The motor shafts are a different diameter.
    Originally both came with thin black inserts that were epoxied in. Kits are available for this but I do not recommend them. You would have to glue these in with precision so the disc runs true in 3 dimensions or it will vibrate.
    The front vari disc still is made this way. The rear now comes with a thicker green insert. This is not replaceable.
    When replacing these, I usually replace both front and rear discs, plus the belt and the three bearings in the front. This assures a head that will not need further attention in that area.
    George
    Jun 2012
    125
    ordered the new varidisc assembly from H&W all is well now. smooth as silk
  1. Head Rebuild
    By MSGMachine in forum Bridgeport / Hardinge Mills
    Last Post: 03-07-2010, 09:03 PM
  2. Bridgeport J-Head Rebuild Question
    By Rockabye74 in forum Bridgeport / Hardinge Mills
    Last Post: 05-27-2008, 01:01 AM
  3. Bridgeport variable speed J-head rebuild (help anyone!)
    By SMG in forum Bridgeport / Hardinge Mills
    Last Post: 11-22-2006, 04:23 PM
  4. 2J head rebuild, What did I miss??
    By Stillearnn in forum Bridgeport / Hardinge Mills
    Last Post: 10-25-2006, 08:21 PM
  5. Bridgeport J-Head Rebuild Kits?
    By jdelaney44 in forum Bridgeport / Hardinge Mills
    Last Post: 05-28-2005, 06:24 PM
