586,094 active members*
4,083 visitors online*
Thread: Linistepper
Results 1 to 8 of 8
    May 2005
    11
    Linistepper
    Hi!
    I would like to make linistepper but can't find PCB
    I found only layer without tracks ( http://www.piclist.com/images/member...-Q33/board.jpg)
    Mar 2004
    261
    Kits for sale and PCB alone at http://www.piclist.com/techref/io/st...step/index.htm
    $35.00 for 3 boards.
    Good luck.
    May 2005
    11
    Quote Originally Posted by rippersoft
    Good luck.
    I know that, but I want to make pcb at home, is that possible?
    Mar 2004
    261
    If you search for Linistepper in this forum, you will find several threads that talk about making the PCB. Here is a thread I found that has a PCB image. You may want to contact the folks who are going this. I believe they are using Eagle for the layout.
    http://www.cnczone.com/forums/showth...ht=linistepper
    Good luck.
    Mar 2004
    261
    Update: http://www.piclist.com/techref/io/st...ep/gallery.htm
    Scroll down the page and look for Posix. It looks like board files are posted.
    May 2005
    11
    Hi!
    I saw that, and first, I wanted to build that, but I think that it is problem to put this board on heatsink. Then I started drawing my own single layer board, but I didn't make it... I will try to make my borad; but if i fail, I will make this one.
    One question: If I put my power transistor on heatsink, and connect them to borad by wire, would I make a mistake?
    Good luck.
    Thank you!
    Mar 2004
    261
    I don't understand how the board that Posix designed would be hard to get a heatsink attached to it? Heatsinks from salvaged PC powersupplies or a good size strip of aluminum bar or angle would work well. Put one or many 12v fans on the case holding the cards and the cards should stay cool.
    I use a HobbyCNC board with old XT powersupply heatsinks and a 12v fan. These run cool.
    May 2005
    11
    Because I will use one big heatsink, and then I must put whole board on heatsink, if you understand what I mean, I can't put L profil on 4 transistors like on original linistepper, because 2 transistors are on one side, and 2 on the other sinde of board.
    And I am not sure if heatsinks from PC power suply would work fine...
