586,113 active members*
3,393 visitors online*
Results 1 to 7 of 7
    Feb 2004
    71
    slaving axis'
    I'm looking to slave to axis together, but it's a little different than usual.
    I use a stepper as a spindle on a pool cue turning machine, and would like to have 2 spindles. They would need to be slaved as they could both turn at the same speed, but the slave function only allows slaving of the linear axis, X Y Z, not the A axis or a spindle.
    Anyone try this?
    Could it be something setup in Brains?
    Any help or direction would be greatly appreciated.
    Royce Bunnell
    Pool Cues | Billiards and Pool Cues | OB Cues
    Jun 2007
    3757
    If both spindles need to do exactly the same, send the same step and directions to both drivers. As no homing switches are need I see no reason why this won't work.
    If you want to control them individually at times you could allocate a outputs to enable each drive.
    Feb 2004
    71
    Neilw20
    Thanks!
    Yes, both spindles will do the same.
    I wasn't sure if the PC parallel outputs could drive 2 stepper driver chips at once. I'm certainly not a TTL guy! I just don't want to smoke anything.
    I'll have to give it a try.
    Thanks again
    Royce Bunnell
    Jan 2006
    2985
    Worst case it would just not work, it wouldn't smoke anything. If you care to be sure, you could use a buffer chip to be sure you have enough current. Put the same input signal to 2 inputs and use 1 output for each stepper drive.
    I'm not sure of your machine configuration but it may be easier to simply tie the two spindles together with a timing belt and pulley.
    Matt
    Feb 2004
    71
    Matt,
    Actually, that's what I have now, a belt between 2 spindles turned by one stepper.
    I use routers to do the cutting with a slot cutter against the spinning pool cue shaft. The trouble is that, because of how they are mounted, the routers are turning opposite directions. The left router cuts down, against the headstock, but the right router turns up away from the headstock and against a spring loaded tail stock. It unloads the cut and slips too much. I have plenty of steppers and an extra driver on this control so I'd like to just add a stepper to that side and swap ends with the headstock.
    I'll give it a try, and try the buffer chip if it doesn't work for some reason.
    Royce Bunnell
    Jan 2012
    28
    machine specs and software
    I am trying to reproduce this machines capabilities.
    Would you post your machine specs and some pics.
    List of software would also be helpfule.
    Thanks Jack
    Legacy CNC Woodworking - Artisan II CNC
    Feb 2004
    71
    Quote Originally Posted by hollisin View Post
    Thanks Jack
    I don't have an easy way to get pics, but here's some basic information on the machine.
    It's an upright rectangular frame of 8020 with rails on the inside of the long uprights. The shuttle rides along those rails, up and down which is my X axis. On the shuttle is a short movement for my Y axis.
    I have 2 routers, one mounted on each side of the shuttle. X moves them up and down, Y moves them in and out. I mounted small dovetails lathe beds on the frame with head stocks and tail stocks from Taig tools.
    It's stepper driven using Mach3. This machine has an old Xylotex control, but most of my machines have been switched to the Gecko drives.
    Royce Bunnell
  1. Need advice about slaving axis
    By Rene Nuñez Paz in forum DIY CNC Router Table Machines
    Last Post: 08-26-2011, 08:16 PM
  2. Slaving more than 1 axis
    By jlmold in forum Mach Software (ArtSoft software)
    Last Post: 03-22-2011, 01:52 AM
  3. y axis slaving off
    By electric2u in forum Mach Mill
    Last Post: 04-29-2010, 02:17 AM
  4. X/A axis slaving issues
    By jhowelb in forum Mach Mill
    Last Post: 10-22-2009, 05:41 AM
  5. Slaving axis & other issues
    By Georgie in forum Mach Mill
    Last Post: 04-17-2009, 09:19 AM
