When creating a machining sequence in Edgecam 2012 and you want to repeat an operation you can copy it by holding Ctrl and dragging it to the location you want it in the sequence. Then you have to edit it and check "Coord Input" to select the new geometry, path or whatever you want for the operation. My problem is that it keeps what you already have selected from when you made the copy. So if you forget to deselect your old paths your tool is going follow the old path again and then do the new path you select. Is there a setting somewhere that will allow me to turn off this feature, so when I check "Coord Input" nothing is selected and it is waiting for me to select the new tool path only. Thanks for any help.
