586,070 active members*
3,543 visitors online*
    Jan 2010
    134
    Star ECAS 20/32
    Anyone have programming examples of the polygon operation on the Siemens control ECAS 20?
    Or if you know the G-command, I could figure it out from there. The Star operation manual doesn't have the G code listed for polygon.
    thanks,
    Dave
    Oct 2010
    21
    Hi I also need any document about ECAS20 maybe we can help each other
    I don't have programming manuel bad point
    [email protected]
    Nov 2018
    Re: Star ECAS 20/32
    CH1
    ;Star_Ecas_Metric 2022/8/24
    ;CH1 PROGRAM FOR Star_Ecas_20 POST PROCESSOR VERSION 138
    Star0=7.0 ;BAR DIA
    Star1=30.5 ;PART LENGTH
    Star2=4249 ;CUTOFF RPM
    Star3=3.0 ;CUTOFF WIDTH
    Star4=165.5 ;ZERO POSITION
    WCS120
    TOPCUT
    G0 G95
    M131 ; (1)
    ;COLLET RECHUCK
    TOP:
    M5
    MS1
    G97 M3 S500
    M11
    G0 Z9.5
    M25
    waitm(900,1,2,3)
    M20
    M10
    G28 X0.0
    waitm(902,1,2,3)
    M131 ;Z Path 1 on (2)
    msg("N1 Face Off")
    ;N1 Face Off
    T202 ;OD Turn-GANG
    JP11
    N1
    EJP11:
    MS1
    G97 S6536 M3
    G95 G0 Y0.0 Z0. T2
    X8.4
    G18
    G1 X6.4 F0.177
    X-0.6
    X-2.6
    M1
    msg("N14 Front Turn")
    ;N14 Front Turn
    MS1
    G97 S6991
    G0 Z-0.761
    X-0.573
    G1 X1.124 Z0.088 F0.062
    X1.324 Z0.188
    G2 X1.5 Z0.4 CR=0.3
    G1 Z6.076
    X2.324 Z6.488
    G2 X2.5 Z6.7 CR=0.3
    G1 Z12.43
    X6.4
    X7.814 Z13.137
    G28 X0.0
    M1
    msg("N3 Threading")
    ;N3 Threading
    T403 ;Threading
    JP12
    N2
    EJP12:
    MS1
    G97 S3879 M3
    G95 G0 Y0.0 Z4.4 T3
    X6.5
    G18
    G291
    G76 P011060 Q013 R000
    G76 X1.948 Z11.5 P276 Q100 F0.45
    G0
    G290
    G28 X0.0
    M1
    msg("N13 Finish Turn")
    ;N13 Finish Turn
    T202 ;OD Turn-GANG
    JP13
    N3
    EJP13:
    MS1
    G97 S7340 M3
    G95 G0 Y0.0 Z10.951 T2
    X4.197
    G18
    G1 X2.5 Z11.8 F0.062
    Z19.127
    X5.7 Z20.051
    G2 X6.0 Z20.31 CR=0.3
    G1 Z30.8
    X7.414 Z31.507
    G28 X0.0
    M1
    msg("N5 Back Turn")
    ;N5 Back Turn
    T303 ;Back Turning
    JP14
    N4
    EJP14:
    MS1
    G97 S4780 M3
    G95 G0 Y0.0 Z25.5 T3
    X8.0
    G18
    G1 X6.0 F0.036
    X5.0
    Z28.0
    X3.695
    Z30.5
    X7.295
    G28 X0.0
    M1
    waitm(904,1,3)
    M133 ;Z Path 3 on (3)
    ;PART EJECTION
    waitm(906,1,2,3)
    M133 ;Z Path 3 on (4)
    ;SUPPORT PART
    T100
    G28 X0.0
    M131 ; (5)
    M141 ;Z1-Z2 SYNC OFF
    waitm(910,1,2)
    M26
    M80
    BAREND
    EM80:
    MS1
    M5
    M99
    M30
    CH2
    ;CH2 PROGRAM FOR Star_Ecas_20 POST PROCESSOR VERSION 138
    WCS130
    T2000
    G0 G95
    ;COLLET RECHUCK
    TOP:
    waitm(900,1,2,3)
    M20
    M25
    waitm(902,1,2,3)
    msg("N8 Face Off - Sub")
    ;N8 Face Off - Sub
    M75
    T4141 ;OD Turn-Sub
    WCS132
    JP26
    N6
    EJP26:
    MS2
    G97 S7045 M3
    G95 G0 X8.15 T41
    Z0.
    M1
    X8.15
    G1 X6.15 F0.1771
    X-0.7
    Z-1.0
    M1
    msg("N9 Turn Out - Sub")
    ;N9 Turn Out - Sub
    MS2
    G97 S8000
    G0 Z-0.6778
    X2.0272
    G1 X3.4414 Z0.0293
    X3.6414 Z0.1293
    X5.0556 Z-0.5778
    G28 Z0
    EM75:
    M1
    msg("N10 Tap 1.6")
    ;N10 Tap 1.6
    T4242 ;Spot Drill-Sub
    WCS132
    JP27
    N7
    EJP27:
    MS2
    G97 S1925 M3
    G95 G0 X0. T42
    Z-1.0
    M1
    G291
    G83 Z1.05 F0.0254
    G80
    G290
    G0 Z-1.0
    G28 Z0
    EM75:
    M1
    msg("N11 Tap 1.6")
    ;N11 Tap 1.6
    T4343 ;Drill Carb-1.3-SUB
    WCS132
    JP28
    N8
    EJP28:
    MS2
    G97 S8000 M3
    G95 G0 X0. T43
    Z-1.0
    M1
    G291
    G83 Z6.6906 Q50000 F0.033
    G80
    G290
    G0 Z-1.0
    G28 Z0
    EM75:
    M1
    msg("N12 Tap 1.6")
    ;N12 Tap 1.6
    T4444 ;Tap_.35_SUB
    WCS132
    JP29
    N9
    EJP29:
    MS2
    G97 S5971 M3
    G95 G0 X0. T44
    Z-1.0
    M1
    G291
    G84 Z5.3 P1000 F0.35
    G80
    G290
    G0 Z-1.0
    G28 Z0
    EM75:
    M1
    ;PART EJECTION
    msg("PART EJECTION")
    M75
    T2900
    WCS130
    M75
    MS2
    M5
    M14
    G0 Z0.
    M11
    G4 F1.0
    M27;CUTOFF DETECT
    M84
    T0
    EM75:
    G28 Z0
    M15
    T2000
    waitm(906,1,2,3)
    ;SUPPORT PART
    T2000
    waitm(908,2,3)
    G28 Z0
    MS2
    G97 S4249 M4
    M82;SPIN SYNC ON
    M11;SUB OPEN
    G4 X.5
    WCS131 (12.7)
    G0 Z-2.
    M68 ;SPINDLE TORQUE DOWN
    G94 G1 Z25.0 F50.0
    G95 M10 ;SUB CLOSE
    M69 ;SPIN TORQUE NORMAL
    G4 X.5
    WCS132
    M140 ;Z1-Z2 SYNCH ON
    G0 Z=IC(-40.0)
    M69
    M83 ;SPIN SYNC OFF
    WCS130
    MS2
    G28 Z0 M5
    waitm(910,1,2)
    M99
    M30
    CH3
    ;CH3 PROGRAM FOR Star_Ecas_20 POST PROCESSOR VERSION 138
    G28 Z0
    G28 X0.0
    T1100
    G0 G95
    M131 ; (1)
    ;COLLET RECHUCK
    TOP:
    waitm(900,1,2,3)
    M20
    WCS140
    waitm(902,1,2,3)
    waitm(904,1,3)
    msg("N7 MILLFLATS")
    ;N7 MILLFLATS
    MS1
    M5
    G97
    spos[1]=0
    waits(1)
    T1408 ;End Mill_4
    JP35
    N5
    EJP35:
    MS13
    M3 S3762
    G94 G0 Y-6.5 Z29.94 T14
    M7 ;SPINDLE RELEASE
    spos[1]=180.0
    M6 ;SPINDLE CLAMP
    X3.2
    G1 Y6.5 F170.0
    M7 ;SPINDLE RELEASE
    spos[1]=120.0
    M6 ;SPINDLE CLAMP
    G1 Y-6.5
    M7 ;SPINDLE RELEASE
    spos[1]=60.0
    M6 ;SPINDLE CLAMP
    G1 Y6.5
    M7 ;SPINDLE RELEASE
    spos[1]=0.
    M6 ;SPINDLE CLAMP
    G1 Y-6.5
    M7 ;SPINDLE RELEASE
    spos[1]=300.0
    M6 ;SPINDLE CLAMP
    G1 Y6.5
    M7 ;SPINDLE RELEASE
    spos[1]=240.0
    M6 ;SPINDLE CLAMP
    G1 Y-6.5
    M17
    G28 X0.0
    MS13
    M5
    M7 ;SPINDLE RELEASE
    M1
    N8 ;Face Off - Sub
    N10 ;Tap 1.6
    N11 ;Tap 1.6
    N12 ;Tap 1.6
    waitm(906,1,2,3)
    msg("N6 Cut Off")
    ;N6 Cut Off
    T1111 ;Cut-off
    JP31
    N1
    EJP31:
    ;SUPPORT PART
    waitm(908,2,3)
    MS1
    G97 S4249 M3
    G0 Z30.5
    M82;SPIN SYNC ON
    G95 G0 Z30.5 T11
    X9.0
    G18
    G1 X7.0 F0.053
    X0.
    Z31.0
    M131 ; (5)
    M83 ;SPIN SYNC OFF
    M1
    M99
    M30
    Nov 2018
    Re: Star ECAS 20/32
    I am now experiencing file transfer to machine?
    my mail [email protected]
  1. STAR ECAS w/Iemca Genius 120?
    By ChristianK in forum CNC Swiss Screw Machines
    Last Post: 10-19-2012, 01:11 PM
  2. Star KNC-32 or KNC-20 (looking to buy)
    By bernemedical in forum CNC Swiss Screw Machines
    Last Post: 08-30-2011, 04:50 PM
  3. Star Ecas Programmer
    By Brian Cerkas in forum Employment Opportunity
    Last Post: 10-21-2010, 08:14 PM
  4. Star VNC 32
    By AvtekMfg in forum CNC Swiss Screw Machines
    Last Post: 01-24-2010, 08:31 PM
  5. ECAS 20 - Profibus-DP: fault of drive
    Last Post: 07-21-2009, 09:43 PM
