586,102 active members*
2,394 visitors online*
    Jun 2012
    Connection using Telnet
    good morning to all,
    does anybody know how to access the HAAS controllers via ethernet connection using Telnet protocol, port 23?
    It asks for Login and Password and it's not the Login and Pass used for direct network connection....
    Direct connection is working fine, file transfer, pc access to directory files on the controller and controller access to windows server it's all working.
    I need to get machine status and data using Q commands, Telnet via port 23 is a possible way to do it in a controlled manner.
    is there a standard login password that can be used? a default maybe? should it be used just for technical access? the Haas tech does not know it, they never used it.
    Is it possible that it requires a specific Telnet software? Upon connection it does respond in the correct manner giving the Machine ID and a request to insert Login.
    We have tried ADMIN ADMIN, LOGIN PASS, LOGIN blank, ADMIN blank, and the login/pass configured in 909 and 910.
    Anybody? please
    Jul 2016
    30
    Re: Connection using Telnet
    Better late than never?
    1. There is no username or password for the telnet connection on a Haas machine. Leave both blank.
    2. That is not the way to issue Q commands. The telnet interface will bring you to a WindowsCE prompt that does not accept Q commands.
    This is how you access Q commands:
    https://diy.haascnc.com/reference-do...tion#gsc.tab=0
  1. V.9.0 Cam Connection
    By Loui in forum Uncategorised CAM Discussion
    Last Post: 09-30-2013, 11:05 PM
  2. Using TELNET Connection
    By orgtec in forum USB, RS232, PARALLEL etc
    Last Post: 09-14-2012, 07:46 PM
  3. Using TELNET Connection
    By orgtec in forum DNC Problems and Solutions
    Last Post: 07-13-2012, 09:24 AM
  4. DB9 Connection
    By denz in forum Gecko Drives
    Last Post: 09-12-2009, 11:49 AM
  5. cnc connection
    By nona in forum Excitech routers
    Last Post: 08-28-2009, 06:54 PM
