586,656 active members*
3,745 visitors online*
IndustryArena Forum > MetalWorking Machines > Tree > setting part zero question
    Mar 2011
    24
    hey all,
    i have a j325, delta 20 control. i don't really have a problem initially setting the zero. but if say i shut the machine down and come back the next day to finish the part is there a good way to get the machine back to the same position with out using the edge finder again.
    tks in advance
    Feb 2009
    6028
    Use the E1 fixture offset. This requires you of coarse on a J325 to make sure you reference the machine correctly, since they don't have zero return switches.
  1. Matsuura 710 - setting up part zero
    By cncelect in forum Uncategorised MetalWorking Machines
    Last Post: 01-05-2012, 03:09 AM
  2. Question about setting up viper drives.
    By Jackal66 in forum Viper Servo drives
    Last Post: 07-18-2010, 02:10 AM
  3. Help please... setting a part in a Lathe :(
    By maltria in forum Uncategorised MetalWorking Machines
    Last Post: 04-30-2010, 10:41 AM
  4. part setting issues.
    By autobionics in forum Bridgeport / Hardinge Mills
    Last Post: 06-13-2009, 09:54 PM
  5. Help with setting up this part
    By skipper in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 06-17-2008, 08:17 AM
