586,110 active members*
3,230 visitors online*
IndustryArena Forum > MetalWorking Machines > EMCO CNC Machines > EMCO Lathe > Parting TM02 Control from Emcoturn 140/240
    Dec 2009
    521
    I am going to upgrade the control so I am parting out the original TM02 control. It is missing the video board and the keyboard. Also selling the original 5 phase stepper motors as well as the stepper driver boards. I also have the 240/380V 10KVA Transformer that will be sold. Spindle motor is also available.
    Contact me directly if interested in any of these parts. Here are pictures of the machine:
    https://picasaweb.google.com/marty.e...ga/Emcoturn240
    Hope this was ok to post here.
    Marty
    Mesa, AZ
    escarcegaATcoxDOTnet
    Sep 2012
    hi marty i have a emco 220 with tm 2 control wanted to see if any parts are the same and also if you run it on regular 3 phase power or a phase conveter i have a american rotary converter with digatal switching and the 380 transformer but spindle alarms out i think it gets a voltage over reading any suggestions thank you nichols marlon 12
    Dec 2009
    521
    Quote Originally Posted by nicholsmarlon12 View Post
    I can't tell you for sure if the parts will interchange. Possibly. I would check the voltage output of that rotary converter. It might have one leg too high. Be careful, you don't want to damage that control.....
  1. Vmc-100 tm02 problem , Lines on monitor
    By dahlman in forum EMCO Mills
    Last Post: 09-17-2020, 09:19 PM
  2. Is a boss 3 control worth parting out?
    By jcox1968 in forum Bridgeport / Hardinge Mills
    Last Post: 11-19-2010, 05:35 PM
  3. Emco VMC-100 / TM02 R-parameters?
    By Viilari in forum EMCO Mills
    Last Post: 06-17-2010, 06:39 PM
  4. EMCO Compact 6P CNC with TM02 control
    By RFB in forum EMCO Lathe
    Last Post: 05-13-2010, 04:28 AM
  5. Need s/w and info on EmcoTurn CNC lathe with a Fanuc OT control
    By richarddoucet in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-28-2008, 03:55 AM
