586,106 active members*
3,241 visitors online*
Results 1 to 6 of 6
    Jun 2012
    Angry Mori NV5000 Ball Screw Problems
    I've had to replace 4 Z axis ball screws on machines only 3 years old! Has anyone else experienced or heard of this? Machines run 2 shifts 5-6 days per week.
    Feb 2009
    6028
    I can honestly say i've never had to put a screw in a NV5000. You have lubrication problems then.
    Jun 2012
    The funny thing is that the wear is significantly relative to gravity...on the bottom of the screw. I don't think there is any counter balance. That's a lot of weight with only the nut and screw to support it. Almost a $30K replacement....
    Feb 2009
    6028
    30k? Someone is hosing you big time. Probably 3-4k for the screw, and 8 hours tops to install. Lube should have been checked when the first screw failed. I know of more than one shop running 24 hours a day, six days a week on original 8 year old screws. Mori has been building non counter balance mills since the mid 80's, and those were much heavier heads than a nv back then. The lube is supplied by a mixing valve to mix the oil (dte 24 or tellus 32) with air. Same system as the spindle. Valve is either plugged up or adjusted wrong. You need to pull the air line off the ballscrew, place a tissue in front of it, and run the spindle for a couple hours at a low rpm, say 100. Check the tissue later and see if you see oil discoloration on it.
    Jun 2012
    it's actually 7k per machine. and you are right it's an 8 hour job.
    Jan 2011
    38
    We have an NV5000 and it was brought to my attention they never had to fill the oiler.... Needless to say this raised an alarm in my book. I called in a tech and had them adjust a parameter so it oils more frequently. How often are you filling the oiler?
  1. Mori Seiki SL-15 1989 X axis Ball Screw
    By 3snc in forum Mori Seiki lathes
    Last Post: 01-28-2016, 02:45 PM
  2. Need Help on Mori Seiki NV5000
    By dannifer.ebot in forum Uncategorised MetalWorking Machines
    Last Post: 07-28-2010, 07:45 PM
  3. Mori SL-00 X axis Ball Screw
    By mrchang in forum Mori Seiki lathes
    Last Post: 03-02-2009, 11:20 PM
  4. G08 on mori NV5000
    By Mill Guy in forum Mori Seiki Mills
    Last Post: 10-25-2008, 12:02 AM
  5. Ball lead screw backlash problems
    By titchener in forum Linear and Rotary Motion
    Last Post: 09-13-2005, 09:34 PM
