Cutting aluminum plate this morning and found play in the router shaft. I am at +500 hours of operation on this router so I cannot complain. Anybody know about where to get a set of bearings and how difficult it is to replace them?
Scott
Scott
They are pretty easy to replace. I messed up my bottom one plowing into a fixture at about 800ipm.
I can't remember where I got one, but I remember that I just googled bosch 1617 parts and found something right away.
Ordered the parts and they should be here Friday.
Scott
Easy fix, helps to heat up the router body to get the bottom bearing in and out. Went through 4 bottom bearings and the top bearing is still good.
Good idea to clean the commutator while its apart too, I used 400 grit sandpaper.
Got the bearings on ebay for under $4 each.
