586,117 active members*
3,327 visitors online*
Results 1 to 7 of 7
    Jun 2008
    43
    Clear all memory of Fanuc 10MA
    Hi All,
    My machining center Mori Seiki Junior with Fanuc 10MA display an alarm:"RAM PARITY ERROR" when power up because the memory back up battery is flat .I need clear all memory but I don't know how to do.Does any one know please help me
    David
    Aug 2011
    2517
    To do a memory clear......
    power on with "7" and "9" depressed
    IPL screen will appear press "99" "Input"
    at the clear question press "Y" then it will ask you the number of axes.
    normally 2 for a lathe and 3 for a mill.
    next it will ask you option #1?
    just press INPUT through all option questions. Should be 32 options
    It will ask to clear data or memory hit "Y"
    Then select option "6" to exit IPL
    Jun 2008
    43
    FANUC 10M OPTION parameter
    Thank you fordav11 for your help.I did all steps as you told but when I exit IPL, an alarm display :
    PC alarm
    PC040 PC error
    PC500 watchdog
    and I can't input any thing more...nor open other screen
    May be these alarms caused by wrong input of option parameter? because I don't have any option parameters so I input 00 when asked option #1 ....
    Please help me solve the problem
    My Email: [email protected]
    Quote Originally Posted by fordav11 View Post
    Apr 2009
    1379
    Correct, you must enter the options in ipl mode; the values are in hexadecimal. If you don't know the options, they are parameters 9900 up.
    Jun 2008
    43
    Quote Originally Posted by memoryman View Post
    Does anyone have option parameters of Mori Seiki MV Junior/Fanuc 10M.
    Please send me a copy.Thanks in advance
    David
    Email :[email protected]
    Jun 2008
    43
    FANUC 10M:MG & TOOL Number setting
    Thank you very much for all helps,thank you fordav11 .Thank your helps, now I can run the machine in manual mode but the machine cannot run in memory mode because there are PMC alarm: 241 Empty pot data set.When I hit NC/PC key,a screen appear:
    [ Tool setting]
    SP Tool : 0 Next tool : 0
    Empty pot : 00
    <MG> <T> <MG> <T> <MG> <T> <MG> <T>
    Data setting MG [ ] T [ ]
    TOOL ATC SETTING
    but I always get an message "Data setting error" when I try to hit the "SETTING" softkey after input the MG and TOOL number (in MDI mode and PWE =1). Is there a wrong operation? Does any one know how to setting MG and Tool number on FANUC 10MA? Please help me fix that problem.Any helps will be appreciate
    Aug 2011
    2517
    did you type in the PMC parameters too? probably not......
  1. Memory Clear / Reset
    By shas595 in forum Fanuc
    Last Post: 04-28-2021, 07:44 AM
  2. KIWA excel-4 w fanuc 10ma control
    By rocketracer in forum Uncategorised MetalWorking Machines
    Last Post: 12-22-2011, 12:00 AM
  3. Fanuc 10ma Drip Feed Directions
    By cncNewGuy in forum Fanuc
    Last Post: 05-20-2011, 01:58 PM
  4. Fanuc 0M command to clear the spindle??
    By Otterpaw in forum Fanuc
    Last Post: 04-01-2011, 06:10 AM
  5. FANUC MEMORY CLEAR & PRECAUTIONS
    By CHANDRU in forum Fanuc
    Last Post: 05-12-2009, 06:16 PM
