586,051 active members*
3,889 visitors online*
    Jun 2012
    Delta 50 Floppy procedures
    Hello out there
    Our company just picked up a Tree 425 with the Delta 50 control. We have a delta20 2 axis on another machine so this is not entirely new ground...
    However, the memory support battery is dead and I suspect it will be a week plus before I can get that replaced (Dynapath says we will likely need the kit from them to bypass the soldered on battery).
    I have a job that we want/need to get running on the mill, and I've already gotten it to work, but I lose the program upon shutdown. (It's short, but still....)
    So my options are to leave the machine on (probably OK) or try to save it to floppy.
    I seem to be able to write the file, but after that point the control cannot read the disk at all. It throws a fault at that point, "Disk seek failure" So I am wondering about the format of the file name, directory, the disk itself, etc..
    I have some NOS discs that were pre-formatted. I am assuming they should work OK?
    Do I have to format the disc somehow on the machine before trying to save files?
    Should I create a directory on the disc? (the "target parameter edit" section seems to have many options for this, but I read somewhere that programs can only be in the root directory)
    Should the file name have a file type suffix? (I've read .txt should work, but I also read that it should only be .OB)
    I guess the other thing could be a bad floppy drive....
    RS232 will be an option down the road but I need something working sooner (like today)
    TIA for any advice
    Aug 2009
    1573
    Re: Delta 50 Floppy procedures
    At the point you were at "TARGET PARAMETER EDIT" type in a new File Name of 8 or less, then press ENTER, then Exit, then Transmit.
    Oct 2003
    102
    Are the disks formatted 720k? 1.44Mb will not work.
    Aug 2009
    1573
    Quote Originally Posted by elnerdo View Post
    I was using fat 1.44 ...blank formatted 1.44 Flop. try replacing your FDD with a know working Unit.. the green light is meaningless.....
    Good luck on the mission,
    DJ
  1. EMUFDD 5.0 Floppy-to-Network & Floppy-to-USB upgrading
    By blackvision in forum News Announcements
    Last Post: 01-19-2013, 09:44 PM
  2. Floppy Controller card PCI floppy drive USB kit
    By logamuthu in forum Want To Buy...Need help!
    Last Post: 11-07-2011, 05:23 PM
  3. how to upload procedures
    By mantenim in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-09-2011, 08:21 PM
  4. cnc procedures
    By mike hide in forum SheetCam
    Last Post: 09-08-2008, 01:13 PM
  5. New Lathe Set-up Procedures
    By B Hebert in forum Mini Lathe
    Last Post: 11-13-2007, 06:57 PM
