586,357 active members*
2,884 visitors online*
    Feb 2009
    6028
    Local variables
    Is there a way to keep the local variable from resetting to zero? We use a lot of nesting and generic programs using variables, but would like them to stay active. Been through every parameter i could find, i did find a M99 won't re-set them, but reset will.
    Thanks.
    Nov 2007
    188
    local variable
    I think you will have to use a Global variable #100 to #199 or #500 to #699 Globals even hold there value after the machine has been shut down reset will not affect them either they stay until you change them.
    May 2004
    4519
    Switch to globals or assign the variable value inside of the program to be run.
    Feb 2009
    6028
    Thanks! Global will work fine.
  1. Are local variables "saved in memory"...
    By gogego in forum Okuma
    Last Post: 04-19-2011, 12:36 AM
  2. Local Variables?
    By TURNER in forum NCPlot G-Code editor / backplotter
    Last Post: 03-03-2008, 01:25 PM
  3. local variables of a macro
    By sinha_nsit in forum Fanuc
    Last Post: 01-16-2008, 01:19 PM
  4. Local variables
    By jorgehrr in forum G-Code Programing
    Last Post: 02-19-2007, 10:03 PM
  5. G65 local variables help
    By FanukRC in forum G-Code Programing
    Last Post: 07-26-2006, 12:00 AM
