Hi! i'm working on a generic FANUC PP for my Mill-Turn Machine.
What i cannot understand is that as i press generate G code I get something like this:
"(1)@start_of_file ==> program_number:5000 g_file_name:'MILL_TURN_1.TAP'
..> full_g_file_name:'C:\USERS\MAURO\APPDATA\LOCAL\SOL IDCAM TEMPORARY FILES\MILL_TURN_1\MILL_TURN_1.TAP'
..> part_name:'MILL_TURN_1'
..> part_full_name:'C:\Program Files\SolidCAM2012\User\Getting_Started_Examples\S W\mill_turn_1.prz'
..> path_part:'C:\Program Files\SolidCAM2012\User\Getting_Started_Examples\S W'
..> index_split_file:1 split_name:''
..> rotate_used:false mirror_used:false fourth_axis_used:false
..> first_proc_number:2 last_procedure_number:1
..> inch_system:0
..> home_number:1 home_changed:false
..> clearance_plane:0.000 tool_start_plane:0.000
..> work_upper_plane:0.000 zero_plane:0.000
..> stock_x_plus:15.850 stock_y_plus:15.850 stock_z_plus:1.000
..> stock_x_minus:-15.850 stock_y_minus:-15.850 stock_z_minus:-28.000
..> stock_x:31.700 stock_y:31.700 stock_z:29.000
..> bound_x_external:15.850 bound_z_max:1.000
..> bound_x_internal:0.000 bound_z_min:-28.000
..> clamp_external:1
> :5000 (MILL_TURN_1.TAP)
(0)@def_turn_tool ==> tool_number:1 tool_position_in_turret:1 tool_position:A spindle_position:0.000
..> tool_id_number:0 tool_id_string:'0'
..> tool_offset_long:1 tool_offset_number:1
..> tool_direction:ccw tool_mode:face insert_face:back
..> tool_origin:T_tangent nose_point:2
..> tool_message:''T tool_type:Ext_ROUGH
..> tool_drill_lead:0.000
..> tool_A:25.000 tool_B:5.000 tool_C:20.000
..> tool_D:55.000 tool_D1:3.000 tool_D2:3.000
..> tool_E:5.000 tool_F:55.000 tool_G:0.000
..> tool_H:0.000 tool_K:0.000
..> tool_ALFA:60.000 tool_BETA:5.000
..> tool_Radius_alfa:0.000 tool_Radius_beta:0.000
..> TurretName:'Spindle' tool_used_in_main_spindle:1 tool_used_in_back_spindle:0
..> number_occur_of_tool:1
..> setup_angle:0.000 tool_tip_z:-60.000 tool_tip_x:-55.000 multi_tool_pos:0"
Is there something wrong with .GPP , .PRP or .VMID files... because it seems that it doesn't compile the G Code...
Thanks a lot...
