My DIY CNC machine has been working just fine for a couple of years now but one strange thing keeps happening. I'm hoping someone can tell me what's causing it
1-When the machine is plugged in and powered up but just sitting there with the router turned off and not running a cut file every once in a while I will here a stepper make a bump noise. Like when you first plug in the machine and you hear the steppers lock up. When this BUMP noise happens one of the axis direction will reverse itself. Most of the time it's the Z or Y axis and very rarely it will be the X axis.
2- If I unplug the machine and plug it right back in everything goes back to normal.
3- It never does this when running a actual cut file (Which is good)!
4- The limits all work fine. All wiring to motors are done using shielded cable with the standard star wiring to ground.
5- I'm thinking its some issue with the drivers getting a false signal but do not understand where it's coming from.
6- Running Mach 3 and a standard Keling kit with Keling drivers and C10 breakout board.
Any ideas of where to look for solving this issue.
Stephen Everett in Maine
