586,036 active members*
3,576 visitors online*
    Jul 2012
    Angry Matrix Tool Definition in iso/eia mode
    Just been tasked with linking Variaxis machine to Cam system...eia option is active on the machine but i seem to have a problem tool changing...we would like to use Mazatrol tool data but every time i program a toolchange(T1M6)
    i get an Alarm No214 designated tool error.
    My question is what tool data do i set in the control to make this work
    we can tool change thru a Mazatrol program but get the above error when running eia/iso program....MDI toolchange works giving T001T0M6 command
    if i put this in the program i still get the error
    pulling my hair out now as we wish to run mazatrol and eia programs together
    anyone come across this i have verified with mazak that the relevent iso parameters are set for mazatrol tool lib utilization
    Anyone got any ideas?
    thanks
    Jan 2009
    55
    tool change parameters for eia
    Look in the front of the electrical manual and there is some plc parameters (R).
    There is ones for the language of the tool change command (ie. T01M6 OR T01T00M06) set this for how you want it. Also there is a "R" parameter for tool change via plc you want this turned on. It takes care of moving the head to the tool change position otherwise you would also have to have "G91G30X0.Y0.Z0." before your tool change command. You may also want to set parameter F70 to "1" this allows the tool data in EIA to use the Mazatrol tool data. So you dont have to call up "H" and "D" after the tool change.
    Link to F70 parameter post
    http://www.cnczone.com/forums/mazak_...ol_offset.html
    Jul 2012
    thanks for your help bildoo
    unfortunately i still have the problem with same error code
    what should i be seeing on the tool data and layout screens
    i cannot allocate a iso program on the layout screen
    throws error (i think this is correct thou)
    i have parameters set as follows
    F91 = 00100000
    F93 = 01001110
    F94 = 11001100
    for reading tooldata
    are these correct?
    thanks
    Jan 2009
    55
    Any tool used in an EIA program will not show up in the tool layout page. Only ones used in mazatrol.
    I think your parameters should be:
    F91: 00100010
    F92 is ok
    F93 is ok
    I don't have the list for the 200 alarms Ill look into it further.
    You might want to try typing in T001T000M06 maybe the control wants a full tool number.
    Your "RB" parameter should be:
    RB2:
    bit4 1
    bit5 0
    bit6 1
    bit7 0
    it should tool change using T1T0M6 with those settings.
  1. Tool Definition & Verify
    By Andre' B in forum Mastercam
    Last Post: 03-14-2012, 06:16 PM
  2. Tool Holder Definition Files?
    By dkaustin in forum SprutCAM
    Last Post: 05-16-2010, 03:34 PM
  3. Dovetail Tool Definition?
    By rc30fan in forum EdgeCam
    Last Post: 10-05-2006, 07:54 PM
  4. Tool: Ball Nose definition in BobCad
    By rherman in forum BobCad-Cam
    Last Post: 09-20-2006, 09:48 PM
  5. Tool definition
    By David Da Costa in forum Mini Lathe
    Last Post: 07-04-2006, 04:48 PM
