586,117 active members*
3,505 visitors online*
    Jun 2006
    14
    Heidenhain TNC 415 parameters lost?
    Hi friends
    I encountered a problem with my control and will appreciate all the help I can get.
    The machine is Zayer machining center with Heidenhain TNC 415 control.
    When turning on the machine, after a 45 days shutdown period, a message that the backup batteries should be replaced appeared. The message appeared in German and so are all messages from the control since than, though the language before was English.
    The batteries where replaced but the machine power will not start-up. The user interface is functional and it is possible to brows between the different screens,
    But there is no power to the motors. No error message appears.
    Any suggestions how to approach this problem will be greatly appreciated.
    Thank in advance
    Dec 2011
    99
    You will need the saved data... What was originally the MP4010 and MP7230?
    See the service description (SM_TNC425) "buffer battery" chapter.
    And further sections:
    "Machine Parameter Input <name>.MP"
    "Compensation of the Input Value List for Multipoint Axis Error Compensation <name>.KOR"
    "Downloading Program PLC, Error Messages, and Dialogues Help Texts"
    Jun 2006
    14
    Hi csg67
    Thank you for your swift reply.
    MP 4010=0
    MP 7230 was 0. I changed it to 1, as it appears in the parameters printout
    and the display language changed back to English.
    It looks like some (but not all) of the MP values had changed to "0".
    I wonder which other data (PLC..Etc) had changed too...
    I will have to check and restore all the MP values by hand, out of printed list
    as the backup disk, made 17 years ago, is corrupted.
    Any additional advice will be appreciated.
    Thanks.
    Oct 2008
    16
    Re: Heidenhain TNC 415 parameters lost?
    Hello
    I also have the dreaded problem of missing parameters, the machine is a Zayer bed mill with TNC 407 control, have any of you guys got a copy of parametes that may get me started again.
    I found some parameters on a page in the cabinet but they only go as far as MP1050 so thats as far as i got.
    Any help greatly appreciated.
    Thanks in advance
  1. TNC 360 heidenhain parameters lost
    By Fætteren in forum HEIDENHAIN -> TNC
    Last Post: 09-22-2022, 11:42 PM
  2. Replies: 3
    Last Post: 05-31-2022, 11:50 AM
  3. Parameters lost
    By padams in forum Want To Buy...Need help!
    Last Post: 05-18-2010, 02:09 AM
  4. Lost parameters
    By kangarabbit in forum Fanuc
    Last Post: 03-08-2009, 07:42 PM
  5. Lost parameters on 10T
    By ktb100 in forum Fanuc
    Last Post: 03-29-2007, 06:38 PM
