Has anybody out there used MaxNC software and motors?
I'm converting a DYNA 2400 mill to use w/PC.
The Y axis motor needs to be reversed and the software does have provisions for this.
rr167
rr167
rr167,
I have used the MaxNC software. I bought one of their milling machines a few years back, and although the software worked ok, the machine itself, and their support was dreadful.
I now have a Dyna 2800, converted to PC control using Flashcut, and I couldn't be happier. The Flashcut interface is much nicer to use than the MaxNC, and their support is excellent. Flashcut is a Windows program, MaxNC is DOS (at least it was at the time).
I'm sure the MaxNC is less expensive, and worth it.
mp-
I have build some cnc hot wire cutters with Max NC simple to reverse direction on the motor simply remove and install 180 degrees and it will reverse.
