As far as the "cylinder taper bore" goes, I worked part time for many years in a speed shop/auto machine shop, and never once had any one ask for a tapered cylinder. The straighter, rounder the bore was always the goal.
As the engine heats up the inside diameter of a bore gets bigger in diameter not smaller. This is why you heat a gear or pulley to make a "shrink fit" on a shaft.
