586,104 active members*
3,470 visitors online*
IndustryArena Forum > CAM Software > Mastercam > masterCam x6 install help
    Jul 2012
    6
    i just install home learning edition x6 from masterCam. and every time i try to create a line or changing the grid spacing it wont let me do it. it keep saying 0.0+1E38 then no matter what number you put in the box it will automatic jump back to the old number plz help me out is there a setting need to be change.
    Dec 2008
    3109
    When you type in a number, it must fall within a range.
    That field has a range from zero to 1 ( with 38 zero's following before the decimal ) , & it must be a positive number
    Jul 2012
    6
    is there a setting that i can change? cause my friend he can change to any number be want to
    Jul 2012
    6
    nvm i try to install it to dif comp and it working perfectly.
  1. Mastercam X won't install on Win 7 64-bit
    By wcthomas in forum Mastercam
    Last Post: 01-24-2012, 06:20 AM
  2. Mastercam install error
    By stampman in forum Mastercam
    Last Post: 09-02-2009, 03:38 AM
  3. New Install
    By kolias in forum Machines running Mach Software
    Last Post: 05-22-2009, 06:09 PM
  4. Install
    By jd@apm in forum CNC Machine Related Electronics
    Last Post: 07-01-2008, 06:10 PM
  5. Install help
    By djmickyg in forum LinuxCNC (formerly EMC2)
    Last Post: 12-02-2007, 03:05 PM
