586,317 active members*
3,421 visitors online*
Thread: Edge Finder
Results 1 to 17 of 17
    Oct 2011
    477
    Edge Finder
    An Edge Finder will not survive the spindle running at 5140 rpms.
    Just in case anyone is wondering.
    nitewatchman
    Aug 2009
    986
    My Starrett handled it OK. But 7500 RPM was too much for it.
    Luckily, it was an enclosed mill.
    Mar 2009
    1863
    Quote Originally Posted by nitewatchman View Post
    nitewatchman
    I take it you're speaking from experience.
    You can buy GOOD PARTS or you can buy CHEAP PARTS, but you can't buy GOOD CHEAP PARTS.
    Oct 2011
    477
    Yep,
    Bottom end spun out, went perpendicular to the barrel and then shot off. Counted the ricochets and found it the base of the second wall.
    Rebent the spring ends and put it back together and it seems none the worse for the suborbital flight.
    Reinforces the importance of safety glasses.
    nitewatchman
    Nov 2005
    201
    indicators don't hold you either LOL
    Haha....I've always worried about one flying across the room on me. Thank God its never happened. I was always told 1000 RPM, but I notice the faster you spin it the easier it is to see. What does everyone else use for a spindle speed?
    Mar 2009
    1863
    I always use 1,500 RPM
    Jun 2006
    3063
    Be glad it wasn't a Haimer...
    Mike
    Jan 2007
    1332
    I use 1K rpm. It's really not higher rpm that works best for me in using an edge finder. The real trick to detecting the earliest edge finder "kickout” is to sight along axis of movement so edge finder kickout is seen perpendicular to one’s line of sight just as it touches the edge. If one not is sighting along the axis of movement then the kickout takes place in the direction of sight which is not as evident as perpendicular to one’s line of sight .
    Don
    Mar 2009
    1863
    Here's my edge finder. I like it because I never have to turn the spindle on.
    Feb 2009
    6028
    ~1200 to 1400 rpm. They get less accurate then they already are past that.
    Oct 2011
    477
    Normally, I will use about 1000rpm. The 5140 was a "brain fart".
    nitewatchman
    Jan 2007
    1332
    Quote Originally Posted by Steve Seebold View Post
    I find the cylindrical probe of the old type Starrett edge finder useful for things like finding datums when using spherical tooling balls or finding the edge of roll pins that I use. The spherical tip used on those 3D edge finders doesn’t work for me in the above applications.
    Don
    Jun 2011
    22
    RPM
    I used to always spin them at 2000 rpm. (I buy .2 diameter tipped with 3/8" shank Starrett edgefinders)
    I spoke with at Starrett rep sometime ago and he said they don't recommend anything above 1000 rpm so I now do as he suggested.
    May 2012
    41
    I've found more success with watching the edgefinder perpendicular to the movement and then, instead of looking for the kickout, I put a small flashlight behind the edgefinder and watch for the light to disappear...tedious, but it seems more accurate than kickout which, IMO, goes just too far into the part before kicking....and then reverting back it won't "return" at the same point. Could be my cheapo edgefinder...anyone use the flashlight method?
    Paul - milling since March 2012 - Solidworks/HSMExpress/Tormach1100 user
    Apr 2010
    294
    I run a Huffam edgefinder at 500 rpm - just following the instructions. The kickout method works for me - I'm not going to stick my head in the cabinet to look down the x-axis while the spindle is running.
    Dec 2010
    1230
    Love mine... glad I haven't tested it st 5400 rpm yet
    Just wish I could get the tips locally... and cheaper.
  1. Edge Finder
    By slamman in forum WoodWorking Topics
    Last Post: 05-17-2010, 07:15 AM
  2. Edge Finder
    By Ashish B in forum CNC Machining Centers
    Last Post: 09-13-2009, 09:51 AM
  3. edge finder
    By bbrown2005 in forum Calibration / Measurement
    Last Post: 02-13-2009, 02:18 AM
  4. Edge finder
    By eggo in forum Australia, New Zealand Club House
    Last Post: 08-04-2008, 04:57 PM
  5. Has anyone used this edge finder?
    By l u k e in forum MetalWork Discussion
    Last Post: 03-19-2008, 07:52 PM
