Bridge rectifiers do not go up that much in price for the larger values so go with something like a GBPC3504W 400V at 35 amps.
For the transformers look up Hammond, for a 240/120 or 120/120, I would think you could go with a 4 kva at 60% duty cycle as you are probabally not going to see maximum power on all three motors for any extended time.
You will also need a electrolytic capacitor bank for 5% ripple at that voltage/current around 10,000µfd.
Some amplifier manufacturers recommend grounding the motor negative, if you do, do not ground the secondary of the transformer.
Al.
Albert E.
