586,055 active members*
4,273 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol > T-2 Mazak FX727 board replaced What are D parameters?
    Jul 2012
    Post T-2 Mazak FX727 board replaced What are D parameters?
    I had a lightning strike damage my original FX727B board which handles rs232 comm to my Griffo bros DNC connection.
    I replaced the board with another FX727B board purchased from ebay.
    I installed a new battery, it was missing, and started up the machine.
    The display showed a C axis which we don't have but I proceeded to start setting parameters.
    On start up got nasty error for invalid M1 - M16 codes no big since the "new" board needed parameters
    Entered all parameters from my backup paper list from previous FX727 board, even the evil OP1 - 16 which required a character for the number of bits set.
    Then hit page and found the "D" parameters D1 - D64
    I did not see them when i backed up my parameters on the old card the page did not show up.
    Are these the hidden parameters and how can I see them on my old card?
    What are they and how do i get correct values for them?
    Jul 2012
    Smile All is well thanks to MEUA Mitsubishi
    After loading hard copied parameters by hand the D parameter page went away.
    From MEUA learned how to access additional pages by pressing F3 key and inputing 1131.
    The hidden pages were all ATC parameters which I blanked and the controls then worked correctly
    MEUA also went through the parameter list I had and confirmed we had all known parameters in.
    Thanks to MEUA
  1. Mazak parameters
    By reno5214 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-11-2017, 06:32 AM
  2. Mazak qt30 parameters
    By Duesentrieb in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-12-2012, 01:21 AM
  3. MAZAK T32-3 Backlash parameters?
    By jacob_tb in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-24-2009, 12:23 AM
  4. Replies: 40
    Last Post: 02-08-2008, 12:03 AM
  5. mazak h-800 parameters
    By Denis13 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-22-2008, 09:23 AM
