586,326 active members*
4,023 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > How do YOU use a micrometer?
Page 2 of 3 123
Results 21 to 40 of 52
  1. #21
    Aug 2009
    684
    Will get back to you as soon as my measuring equipment is cool enough to handle (have purged it with oxy flame to remove any contaminants). I would quench it all to speed up the process but I don't fancy picking the slips out of the oil vat.
    DP
  2. #22
    My preference is not to use the lock on the mic and only use it when I absolutely need to , quite often the lock will knock the measurement out .0002 , I've seen it far too often with different mic's over the years while setting bore guages , Mitutoyo seems particularly bad for it
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
  3. #23
    May 2004
    4519
    Or...you can just you your mics as paperweights to hold prints down so the shop fan does not blow them away and call the QC guy over to measure all of your parts for you.
  4. #24
    Quote Originally Posted by txcncman View Post
    who's that comment directed at ?
  5. #25
    Feb 2007
    664
    on the 4th i used them to pop some caps off . they pop around .00472 , but you gotta spin it quick
  6. #26
    May 2004
    4519
    Quote Originally Posted by dertsap View Post
    Since it did not include your name it was not directed at you. Are you so smart as to think that if a post immediately follows your post that the new post is a direct result of your post? Do you think you trigger every event that happens in the world?
  7. #27
    nothing like a simple answer to a simple question now is there you ignorant know it all know nothing pos , it must have been directed towards someone . it seems to keep in track of worthless posts that you pollute these forums with , if it isn't your typical ignorant remarks , then it's to answer a question with a question rather than to offer a solution (which it's clear that your incapable of )
  8. #28
    May 2004
    4519
    Let me simplify for you. No, my comment was not directed at you.
    Again, I have been shown the error of my ways by one so much greater than myself. Your intelligence (or lack there of) leaves me speechless. Good day.
  9. #29
    Jan 2011
    47
    I use my mic to set up my bore gage when I don’t have a ring gage close. I assemble gage blocks to the dimension needed, set the mic to the gage blocks, lock it and slide it off. Then use the mic to set the bore gage.
    Jim
  10. #30
    Aug 2009
    684
    Good thinking JWH. I'm having difficulty wringing my slips together at the mo after purging them, even though I made sure I stoned them to remove any scale residue..
    Thought it might be interesting to hear thoughts on internal mic measuring techniques. I personally have developed a method I call "score the bore". I basically set the mic to bottom limit (be sure to double check against a good external mic) and then pass it through the semi-finished bore. Don't worry the mic will centralize itself as you pull it through. It will leave a gouge. Continue machining until gouge is removed and voila, you have achieved size.
    DP
  11. #31
    May 2010
    Quote Originally Posted by christinandavid View Post
    DP
    ^^^ This guy. I'm laughing so hard I wet myself.
  12. #32
    Sep 2010
    31
    Quote Originally Posted by J S Machine View Post
    I've been in the trade for a number of years and one of the first skills I learned was how to use a micrometer. Everybody knows you have to know how to use measuring equipment in this trade.
    I work around other machinists / tool and die makers. One of the things that drives me nuts is their use of a mic. Now I may be wrong, but I just don't understand why people do the following:
    1. Place mic over / around part.
    2. Twist the thimble down until measuring faces make contact with the part.
    3. lock the mic.
    4. Drag it off.........
    Why do people do this?????
    I cringe every time I see the guys I work around do this. I've always done the following:
    2. Twist thimble down until measuring faces make contact with the part.
    3. READ the mic
    4. Untwist the thumble and gently remove it.
    I just don't get why peole drag the mic off of the part! To me, this just wears the faces that much faster. There is a possibility of chipping the faces if they are carbide. Also, if the part is out of square, and just happens to get larger in the direction you are pulling, this torques the mic...
    Probably something dumb to get upset over, but I just can't stand to see people abuse their mics in this manner. It seems that way to me anyway..lol
    Is it possible that they are afraid to lose the reading if they open the mic up again?
    Just a thought.
    Nelson
    South Bend Heavy 10L, Burke #4, Van Norman #12, South Drill Bend Press
    A home machinist site you might like: www.Hobby-Machinist.com
  13. #33
    Mar 2005
    1136
    Quote Originally Posted by underthetire View Post
    Thats why they have carbide faces, and i have never seen one chipped from this.
    I
    +1 and I've handled hundreds.
    A very good reason for removing the mic for reading is to have a proper view position and light and to eliminate parallax error; especially if looking at the tenths vernier.
  14. #34
    Sep 2010
    31
    Is the clamping pressure placed on the workpiece supposed to be so tight that it cannot move and the ratchet slips, or it is supposed to be just tight enough so the barrels of the mic make contact, or something else? Some of the posts here seem to indicate both.
    Which is correct?
    Thanks,
    Nelson
  15. #35
    Aug 2009
    684
    If the barrels make contact then that MUST surely be over-tight as it means you have punched all the way through.
    Since moving onto horizontals I have found an advantage over vertical setups. You can GUARANTEE consistent torque of your mics while working perpendicular to gravity - simply hang weights off the mic (This, in case you are unaware, is the purpose of the series of holes through the body of the mic) and record the point at which the mic starts to move. With practice you can set ANY size mic to slip at a certain point, and you are on the way towards ultimate accuracy.
    DP
  16. #36
    Sep 2010
    31
    Contact with the workpiece, not with each other...
    Nelson
  17. #37
    Sep 2006
    6463
    Hiiiyyyyy guys, having spent the last 50 years or so hacking metal, it occured to me that there must be hundreds if not thousands of parts in existance that I made that got measured by clamping, squeezing or sliding the mic' faces on the parts, and not one of them was ever returned as not to drawing or out of tolerance.
    So who is right....nobody.
    In a test that was carried out at random a number of tool makers were given a mic and asked to measure a gauge block pack without knowing the size of the blocks.
    Needless to say they all got different results.
    Personally I always use the mic barrel ratchet....you can't overtighten the ratchet or have it too loose......no two people have the same feel with a mic.
    Incidently, when you are using a go/no go slip gauge, when is the part correct......when the gauge can be slid off the job easily at top limit or must it be firm on the job......same as for bottom limit.....tight or loose?
    I would go further and state that it is impossible to measure a job to within .0005" (half a thou) without proper measuring equipment, and that ain't a hand held micrometer, and you can forget it too if the temperature of the day is either freezing cold or boiling hot.......that's precision B/S to impress the noobs.
    Ian.
  18. #38
    Feb 2009
    6028
    Quote Originally Posted by allthumbz View Post
    Which is correct?
    Thanks,
    Nelson
    Depends on who calibrated them. I have a light touch, as the micrometer will dig in to some materials. I always had to adjust mine after they were calibrated.
  19. #39
    Aug 2009
    684
    Quote Originally Posted by handlewanker View Post
    I was always told by inspection department that size-on-size won't go. You should always allow for this when tolerancing your gauge, or it could reject a good part.
    My personal preference is to always tap with a hammer to make doubly sure. Extra skill and caution is required at this point though; gauge MUST be perfectly square before hammering commences.
    DP
  20. #40
    Sep 2010
    31
    How do you make that adjustment?
    Nelson
Page 2 of 3 123
  1. Blade Micrometer
    By castle machine in forum Want To Buy...Need help!
    Last Post: 12-21-2011, 01:42 PM
  2. micrometer without spinning jaw?
    By Phooey in forum Linear and Rotary Motion
    Last Post: 05-07-2011, 04:03 AM
  3. How do I adjust a Mitutoyo 103-116 micrometer
    By hercengineerjay in forum Calibration / Measurement
    Last Post: 04-18-2010, 08:35 PM
  4. micrometer
    By hkrok in forum News Announcements
    Last Post: 08-15-2007, 02:56 AM
  5. Ratchet/R-F stop micrometer
    By fpworks in forum Calibration / Measurement
    Last Post: 02-04-2007, 05:54 PM
