586,655 active members*
3,230 visitors online*
    Jun 2006
    14
    TNC 415 data cable
    Hi
    I'm intending to connect my Heidenhain TNC415B to a laptop for parameters and data backup (and restore). The TNC has a 25 pin serial socket.
    I was told that i would have to get an USB to RS232 adaptor for the Laptop.
    I did not get that adaptor yet, so I don't know if its 9 or 25 pin.
    Which cable configuration I should use to connect the laptop to the TNC?
    Can someone send a schema?
    Thanks in advance
    Z.
    Jan 2011
    350
    On attached file: This is the RS232 pinout for TNC 430. Should be exactly same thing for TNC 415.
    Btw mods maybe it'd be nice to have a Heidenhain section in the Machine Controllers Software and Solutions part of the forum. I know they're big on scales, but I think Heidenhain are the 4th or 5th biggest player even for numerical controls.
    Cheers.
    Jun 2006
    14
    Thanks Botha.Y
    I'll try it.
  1. Best way for data transfer?
    By pontiacg5 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-24-2010, 07:32 AM
  2. AC power cable in the same cable carrier with motor cables
    By bandtank in forum CNC Machine Related Electronics
    Last Post: 06-02-2010, 12:06 AM
  3. Replies: 0
    Last Post: 01-22-2010, 07:06 PM
  4. Computing Cable Rotation From XYZ Point Data
    By FishGuy876 in forum Uncategorised CAM Discussion
    Last Post: 09-17-2007, 07:55 PM
