586,112 active members*
3,173 visitors online*
Page 8 of 8 678
Results 141 to 153 of 153
  1. #141
    Jun 2008
    1082
    Re: I love my Tormach, but...
    I bet they're both completely machine finished. Would you say face-milling steps outside the bounds of "machine finishing"?
    I wonder what the flat edge at the bottom of the bottom photo would look like if it was photographed with the same angle/camera/lighting as the Tormach/Mori set of photos from earlier.
    Quote Originally Posted by waltpermenter View Post
    has it been established that the part in jid2s pics are indeed the 6061 most of you are limited to experience with? an alloy with more zinc will give a nice shiny finish right off the machine, yes even on a tormach. there are a lot more alloys out there used in the industry than 6061.
    walt
    Good question.
  2. #142
    Feb 2011
    605
    You guys are in denial.
    Again, these are not my parts, but feel free to go look at images of the work done here: https://www.facebook.com/pages/Front...08500182556134
    He cares about surface finish, and uses the best tools and equipment he can in order to get great results directly off the machine.
    Here is a quote from the Swiftcarb catalog, "if you're not getting a mirror finish at 300+IPM, then you need to be using Swiftcarb". This is 2014, leverage technology. Again, a Tormach isn't going to do this, but don't tell us you can't.
    PM-45 CNC conversion built/run/sold.
  3. #143
    Sep 2012
    1543
  4. #144
    Feb 2006
    7063
    Quote Originally Posted by jid2 View Post
    Yes, it's amazing what you can do on a $100K+ machine, with a 30HP spindle. But what is the relevance to anything in this forum?
    Regards,
    Ray L.
  5. #145
    Feb 2011
    605
    That someone posted pictures of surface finish from a tormach and a mori and said they were the "same", implying that a tormach or any R8 taper 1000lb machine can create surface finish quality at the same level as a VMC. Thats all.
  6. #146
    Jun 2004
    6618
    I get high gloss finishes too, but those parts come out of the powder coating booth.
    I used to hand polish and buff aluminum parts to a mirror finish. It is work. No doubt about it. I can see why one would want a machine that can produce the type of finish on the recent parts in this thread. High quality parts with less or no hand finishing. That statistic right there means more profit per part. When I did hand polish those parts, they would not stay looking that way even though a wax was applied. Same thing goes for these high machine finishes I would guess. They will never look better than when they come off the machine. Probably quite a bit different when they come out of a box a year or two later unless vacuum packed.
    Lee
  7. #147
    Mar 2009
    1863
    Quote Originally Posted by BAMCNC.COM View Post
    Swiftcarb makes really good end mills, but there is absolutely no way you're going to get that kind of finish off a milling machine. I don't care if you do it on a Tormach, Mitsui Sieki, Kitimura, Mazak, Mori Seiki, Fadal or a Haas, and I have run them all. And I have used a lot of Swiftcarb end mills too, and actually they're no better than any of other high performance end mills.
    You can buy GOOD PARTS or you can buy CHEAP PARTS, but you can't buy GOOD CHEAP PARTS.
  8. #148
    Jan 2007
    1332
    Quote Originally Posted by Steve Seebold View Post
    Swiftcarb makes really good end mills, but there is absolutely no way you're going to get that kind of finish off a milling machine. I don't care if you do it on a Tormach, Mitsui Sieki, Kitimura, Mazak, Mori Seiki, Fadal or a Haas, and I have run them all. .
    Moore Nanotechnology Systems: Ultra-Precision Machining Systems
    Don C.
  9. #149
    Feb 2007
    1041
    Jid2 - reread the post guy, I never said they were the same finish. From my testing I know it's impossible to pull the same finish on this machine. All I was showing was from a part made on a Mori at 7x magnification the Tormach wasn't far behind after the mods. Before the mods the finish was horrible, didn't matter what settings, end mill, coolant, etc.. used, always looked the same/very little difference. I wasn't trying to write a novel explaining every little detail, saw someone asking about the mods and thought I'd chime in and show how they worked for us.
    Hirudin - I don't know what the setting were for the Mori part, but after about 80 test cuts using just about every end mill I could find, tuning the machine and whatever the hell else I did 2 years ago that was my best set. I used a .5" ZRN Accupro 2FL EM OAL length I believe was 1" or 1.25". When testing everything trying to finish at Max RPMs still looked bad, but at about 2000 - 3000 rpm 20 - 35 IPM with a finishing pass of .001" -.002" WOC seemed to work great. It's all about what works for you.
    Thank you Mike !
  10. #150
    Jun 2014
    1780
    Your welcome sir!
    mike sr
  11. #151
    Jun 2014
    1780
    Quote Originally Posted by tbaker2500 View Post
    I liked the anti-vibration properties of the Fenner belt, but I didn't like the whistling. The high-frquency noise is higher.
    The Fenner belt does get quiet after a few years running, mine is dead quiet and doesnt slip after 8 years.
    mike sr
  12. #152
    Oct 2011
    477
    I would second that. I use Fenners on just about everything.
    Quote Originally Posted by popspipes View Post
  13. #153
    Jun 2014
    1780
    I just reread this thread and didnt find a pic of the belt adjustment setup, just in case someone is interested, the motor is also mounted on .0625/.125 silicone gasket material to isolate the motor from the machine frame, this helps a bit with vibration.
    mike sr
Page 8 of 8 678
  1. Love My Job!!!
    By eneias_eringer in forum Benchtop Machines
    Last Post: 07-14-2013, 09:21 PM
  2. Love my Tormach
    By tbaker2500 in forum Tormach Personal CNC Mill
    Last Post: 08-20-2012, 01:24 AM
  3. I Love Grex
    By borrisl in forum Shopmaster/Shoptask
    Last Post: 07-21-2006, 03:15 AM
  4. Do you love boats? Do you love planes?
    By cncadmin in forum Hobby Discussion
    Last Post: 03-20-2006, 04:01 AM
  5. Hmm.. got to love it
    By Pole in forum MetalWork Discussion
    Last Post: 08-28-2004, 12:58 AM
