586,055 active members*
4,376 visitors online*
IndustryArena Forum > WoodWorking Machines > CNC Machining Centers > Biesse Rover 346 start up problems!
    Jun 2011
    Hi guys I just bought a used Biesse Rover 346 from 1995 with CNI 480 controls.
    we have cleaned the machine and put power on but we get a lot of alarms. I can’t size the machine because of some error, and it’s all in German
    and it’s the first Biesse Rover I have tried before, so does anyone have the manuals on pdf I can’t alter the language on the controls that does not help.
    There is a password I have to enter before I can change the language but don’t know how.
    the alarms i get are as following
    ax6X
    mt13
    S02
    S01
    if anyone know how i can proced i would be greatful
    Can anyone help me with a step by step to size the machine so it’s all ready to go.
    Can anyone help me with a step by step to change the language on the machine,
    Anyone have any manuals in English
    Oct 2010
    21
    Quote Originally Posted by num1040 View Post
    ax6X
    mt13
    S02
    S01
    try password 210 it might work if its the same series of cnc's from biesse as my own, hope it works
    Nov 2009
    121
    hello
    do ou need still manuals?
    this has a cost?
    regards
    May 2012
    4
    ax6X
    mt13
    S02
    S01
    I run a '98 Rover 346, dont know if it will work on your machince or not but I had a technician work on my machince a few months ago and the factory password on my machine is "serbs" It was still set as that after two owners luckily. Hope that helps.
    I too, could use pdf copies of manuals in english.
  1. Start push buttons Biesse Rover 13 does`nt light
    By Christiaan in forum CNC Machining Centers
    Last Post: 11-23-2021, 09:52 PM
  2. Need Help Biesse Rover 13
    Last Post: 09-15-2020, 02:42 PM
  3. Biesse Rover 22 Start-Up Problem
    By mgaman in forum CNC Machining Centers
    Last Post: 06-16-2012, 03:55 PM
  4. biesse rover b 4.4 vacuum problems
    By bryane in forum Biesse
    Last Post: 09-08-2011, 01:44 AM
  5. Biesse Rover C
    By Dogfart in forum CNC Machining Centers
    Last Post: 06-07-2009, 05:17 PM
