586,068 active members*
3,687 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Daewoo PUMA 8HC Parameter required
    Jul 2012
    Question Daewoo PUMA 8HC Parameter required
    Hi!
    We buy a used Daewoo Puma 8HC with Fanuc OT B control,year 1989. But unfortunately battery during transportation, Now we need its parameter and diagnostic parameters.
    Kindly help me,
    May 2022
    Re: Daewoo PUMA 8HC Parameter required
    Hi did you manage to get the parameters ? Here is the files if still needed
    Cheers !
    Attached Files Attached Files
    Mar 2023
    We also have a Daewoo PUMA but differs in that it's a 10-HC, Serial Number PH100Z08 and due to a dead battery, we've also lost the parameters. Will these parameters work with it? If not, do you have the parameters for our machine?
  1. Daewoo Puma 12L parameter list
    By DCSABAI in forum Daewoo/Doosan
    Last Post: 05-04-2021, 06:07 AM
  2. daewoo puma 12lb tape format problem/parameter problem
    By robb12877 in forum Daewoo/Doosan
    Last Post: 08-25-2011, 06:13 AM
  3. Daewoo puma 8s
    By mroy0404 in forum Daewoo/Doosan
    Last Post: 06-14-2010, 07:58 AM
  4. I Need to buy a Daewoo Puma 8
    By gcrudgington in forum Daewoo/Doosan
    Last Post: 10-20-2008, 11:24 PM
  5. Daewoo Puma 200
    By williamsxu in forum Daewoo/Doosan
    Last Post: 01-17-2007, 11:52 PM
