586,036 active members*
3,532 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > Fuling Inverter spindle speeds and feed rates
    Jul 2010
    13
    Hey guys,
    I am about to sell my Chinese CNC which I have always ran at factory settings for cabinetry etc.(18000 rpm 3 mtrs per min feed)
    I have a buyer who wants to know how to reduce the spindle speed, and/or feed rates for cutting and drilling plastic and metals.
    I have the DSP and Fuling manuals but dont know where to look to change these parameters.
    Vectric V carve Pro wont alter either, so I assume it has to be manually set, or a feature enabled?
    I have Fuling DZB200 standard DSP HANDLE.
    I am desperate to sell this machine due to re location, but I dont want to give the buyer a machine he cant use, so any help would be most welcome.
    Many thanks
    Alan.
    Feb 2012
    Hi Alan,
    Sorry I didn't see your other post, but hope this helps.
    Here is a link to the DSP Manual, just in case you may have a different manual than the one I am referring to. It's a PDF a few posts in:
    http://www.cnczone.com/forums/contro...p_pendant.html
    On page 15 and 16 the manual covers how to enable F-Code read.
    On your DSP select Menu, then Auto Pro Setup, then G Code Read Setup, then make sure that F Read is set to "Enable".
    Now your machine should take Feed rates from your program software on the thumb drive.
    Unfortunately you still have to manually set the spindle speed for each operation via the Fuling Inverter.
    Matt
    Jul 2010
    13
    Success!!!
    Thanks Matt,
    I can now see a visible change in the feed rates of the CNC.
    You have no idea how much this means!!
    Now I can confidently program feed rates and not 'hope' there is no tear out on some of the trickier timbers I use.
    I still have no luck with the spindle speed adjustment.
    The spindle works though it's 7 stage acceleration, up to max speed of 18,000rpm and 300hz.
    Luckily, most of the cutters I use require this speed, or faster, but I still would like to slow it down for some metal drilling etc..
    I have pressed every button on the DSP , and twiddled every knob on the inverter, with no luck....any ideas?
  1. Calculating feed rates and speeds for ABS
    By d11rdozer in forum Glass, Plastic and Stone
    Last Post: 01-29-2013, 12:19 PM
  2. feed rates and spindle speed
    By alanstclair in forum Chinese Machines
    Last Post: 07-15-2012, 03:25 PM
  3. feed rates and spindle speeds
    By juniormachinist in forum Mastercam
    Last Post: 09-23-2011, 11:03 PM
  4. Can I get some help with speeds and feed rates for steel?
    By slashmaster in forum MetalWork Discussion
    Last Post: 05-15-2009, 10:35 PM
  5. Feed rates / spindle speeds for HF spindle
    By yngndrw in forum Uncategorised MetalWorking Machines
    Last Post: 03-21-2009, 04:46 PM
