Sorry if the link to the project was not working. It should be good now.
One update I will add to the project. It is important that you use extra clamps and use tabs on the milled parts that are large enough to that the stock does not shift.
I am suing a 1/8" cutting pass at 100IPM and that puts a load on the stock. IF you wanted to make a 1/4" cutting pass it would add even more force that would shift the stock or break your part free from the tabs.
On my next gear I will take a more aggressive pass but do a final pass removing .005 from the profile. This should allow me to cut the part very quickly yet still give me a nice part. The key will be how much bit deflection I will get. If its less than .005 then the final pass should compensate.
Author of: The KRMx01 CNC Books, The KRMx02 CNC Books, The KRmc01 CNC Milling Machine Books, and Building the HANS Electric Gear Clock. All available at www.kronosrobotics.com
