Greetings All,
As a die maker of 30+ yrs, I've worked with EDM departments for a long time. Every time I give a burn block to the EDM Dept, I need to grind off a .010 wire nub (we have another name for it, but that may get censored here) from the finished part. My finished product from the wire block is usually a punch that's burned from the wire block. So, essentially, it's a slug. The block is clamped in the wire machine, and my punch is cut out from it. Every shop I've worked at, the process has been the same. I realize there is a roughing pass, and then at least one skim cut. And this material is needed to keep the part attached to the block during the skim cut. Does anyone do this differently, or is it an inherent problem? Is there a better way to program that eliminates the need for me to grind that wire nub? I'm just looking to cut out any undo operations for those really hot jobs.... Thanks, CH.
