586,748 active members*
7,196 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Omni CNC > Details Photos of OMNI CNC Plasma Cutter
    Here are some details of omni cnc plasma cutting machine. Hope you could get more familiar of omni cnc plasma cutting machine.
    OMNI cnc plasma cutting machine can be devided into two kinds mainly according to torch height controller function. One model is with this function, mainly for uneven metal plate, and the other is for even metal plate.
    The following model is torch height controller. The device could sense the metal surface heightness, and then adjust the cutting torch position to cut. For cnc plasma cutting machine, OMNI offer 4 kinds of control system. Weihong controller, DSP, Mach3 and Start.
    Torch Height Controller Details
    Part viewo of OMNI cnc plasma cutting machine control cabinet.
    OMNI CNC plasma cutting machine material-removing table
    OMNI CNC plasma cutting machine table side. Tankchaine uses superior quality, machine is with linear guide, rack and pinion, packing wooden case with humidity proof cloth.
    Amanda Cheung from OMNI, www.omni-cnc.com,
    [email protected], Skype: omni-cnc
    Jan 2011
    5
    hi there
    i have the same machine i kept on sending and calling customer support .he replyed but did not fix my problem.if you don`t fix my problem i will write in the forum stating my experience with your company .
    so please contact me .
    [email protected]
  1. CNC Laser cutter versus CNC Plasma cutter?
    By squale in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-24-2020, 02:14 AM
  2. OMNI Presents Mini CNC Plasma Cutter
    By omnicnc in forum Omni CNC
    Last Post: 06-20-2012, 09:11 AM
  3. details engines details
    By azroyhelmy in forum I.C. Engines
    Last Post: 03-29-2011, 01:47 AM
  4. CNC Plasma Cutter, Laser Cutter, Water Jet
    By antsals in forum Waterjet General Topics
    Last Post: 03-11-2011, 01:56 PM
  5. What is the best plasma cutter
    By jpmassey in forum Waterjet General Topics
    Last Post: 08-26-2007, 07:15 PM
