586,106 active members*
3,204 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > sequential engraving on osp p200m
Results 1 to 6 of 6
    Jul 2012
    i have a mcv 4020 okuma milling center with an osp p200m control and i need to sequentially engrave serial numbers on some four hundred pcs. our machine supplier said it could be done with a macro program and want 1500 bucks for the program as well as a software update for the control to handle scaling of the number letter combo. does anyone have a good example for this control? i found some fanuc examples on cnc zone, can i alter the fanuc code for the osp???
    Mar 2009
    1982
    If I remember correctly, there is at least one *.zip attachment on this forum with character macros. You can adjust Fanuc code for the OSP. What is your forecast - will You need character scaling?
    May 2011
    27
    I have the same same Okuma machine and control in my shop. I use the macro in the link. The added sequential serial number code has not been proven out. (I type in a lot number for each job - see instruction sheet)
    http://www.cnczone.com/forums/937567-post2.html
    P.S. Delete or rem out the "-----------------" in the macro.
    Jul 2012
    i won't need character scaling, i figured i would just toolpath the numbers and write a macro for a six digit serial number. quick and dirty for this four hundred piece lot, would only need to s/n once a year.
    Aug 2011
    7
    Re: sequential engraving on osp p200m
    radial engraving i have a macro if needed
    Sep 2009
    93
    *cough here *cough
    :cheers:
  1. Chinese Laser Cutting and Engraving Machine TS-6040 60w - Engraving problem
    By Andriette in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-24-2014, 03:44 PM
  2. PHCAD setting cut after engraving deeper engraving
    By herby08 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-25-2012, 10:18 AM
  3. Distinction between laser engraving between special LGP engraving machine when produ
    By CUTCNC in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-21-2011, 09:46 AM
  4. OSP-P200M question
    By RebeX in forum Okuma
    Last Post: 03-12-2009, 10:53 AM
  5. sequential cycle rotary engine (SCRE)
    By dr kingston in forum I.C. Engines
    Last Post: 03-22-2007, 10:34 PM
