Hello,
I apologize if this was addressed in another post, but I am having some issues testing my G540 and motors. After eliminating a bunch of things (correct parallel cable, EPP mode and working from a desktop), I can't seem to get any response from my motors when I jog them in Mach 3, with the gecko.xml profile loaded.
I have the charge pump enabled and once started up, the controller goes to ready, which leads me to believe that it is getting a signal from the 16 pin. Mach 3 also resets if I disconnect the parallel cable or unplug, so there is definitely some communication between 'puter and controller. I am pretty sure that I soldered the wires properly (although not very pretty). Cold it be that? A Mach 3 setting? Something I may have missed?
I am at a loss and would appreciate any help.
Thanks in advance.
Alex
:drowning:
