Originally Posted by
handy
Hi i have a kMB 1X and it has just started to give issues!.When starting the operation/program the spindle will spin and will move in xy and z to start point then the spindle just spins and the xyz axis freezes.Also if you try to move any of the axis in operate mode rapid it will only move in one direction ,to get it to move again you have to press operate again and again if you want to move it back.Normally you can access the axis required and pess + and it will move then - and it will move.But after one press you need to press operate again!!!.It also is making buzzing sounds from the xyz motors and machine bed feels rough when moving in x and y and also z spindle(up/down).I have had this fault before and just left the machine and went on holiday.On my return all worked fine again,untill now.I really need to find the source of the problem!
Can anyone advise me on this issue?????.Would be much appreciated!
