I am a dust fanatic. I have a central Cyclone system in my shop and several high end vacuums as well. There are two ways to collect dust from your CNC.
Brute force:
Use a large enough system to overcome all the air turbulent your router creates. In this case you need to have a good seal around your stock (dust shroud) and use a lot of suction. Like connecting you 6” central shop vacuum to your dust hood. This is ok for large machines but does not work very well on small ones.
Work Smart:
I found out a while back that if you can take the vented air from your router and vent it in such a way that it does not enter the dust shroud/stock area, you don’t need a lot of suction to remove most of the dust. You can’t just divert the vented air. The vented air must be isolated from the inside of the shroud. It took me quite a few iterations but this is my final design.
[ame=http://www.youtube.com/watch?v=xta-vQGYts4]Kronos Robotics Air Exchanger - YouTube[/ame]
I call it the air exchanger. Unfortunately the current design only works on CNC machines with a K2CNC router mount.
I use them on all three of my CNC machines. I use Fein Turbo III on one and Rigid $99 shop vacs on the other two.
Here is the link to my AirExchanger product page.
AirExchanger
We are also working on a clamp on version that will attach direcly to most routers.
Author of: The KRMx01 CNC Books, The KRMx02 CNC Books, The KRmc01 CNC Milling Machine Books, and Building the HANS Electric Gear Clock. All available at www.kronosrobotics.com
