I recently rebuilt my CNC setup with new motors and a G540 controller with Mach3. I have downloaded the XML file and have it installed. Everything with the G540 works fine to this point. I can jog the motors at a nice speed and everything "sounds" fine.
However, when I attempt to calibrate the motors I start getting a strange problem. I am using the built in step adjustment and have everything set to the "inches" setting. I tell Mach3 to move the table 1.0" and it moved about 0.640" on the dial indicator. I typed that amount in and it informs that my steps will be set to 32XXX.XXXXX steps and I click OK. When I try to run it again to test the setting, the table moves at a super fast speed, so I adjust the velocity down to an acceptable level, then try the test again. For some reason, using the same 1.0" table move, the table actually only moves about 0.050". I have not changed the setting the calculator has inserted, just the velocity.
I am at a loss, hopefully someone can offer a suggestion or two.
The motors are standard Nema 23 425oz 8 wire motors that are wired bipolar series and are direct drive. As mention, the controller is a Gecko G540 and I am running it under Mach3. I know the computer runs Mach fine as I was using it before I swapped out the motors and the controller.
Thank you in advance for your help.
