Originally Posted by
leix_99
...Some scrapping and lube oil left the table like new,....
Your typo is pertinent. If you did indeed scrape off all traces of superficial rust you are on the way to turning your table into scrap. Just clean the table up with something like (green?) Scotchbrite which will not remove any metal. You will still see a trace of where the vise was but the accuracy of the table surface is not affected. Actually scraping material off does affect it.
