586,907 active members*
3,281 visitors online*
IndustryArena Forum > CAM Software > GibbsCAM > how would i accomplish this in gibbscam?
Results 1 to 12 of 12
    Jul 2012
    High-Speed Machining by Surface Solutions - YouTube
    just looking to remove the corners of a rectangle in this fashion.
    May 2004
    4519
    Looked pretty inefficient to me. I do not think Gibbs has this type of cycle built in.
    Jul 2012
    how would that be inefficient? Ive ran programs like this with mastercam and it really improved the life of the tools we used. Now that i have my own mill and forked over the cash for gibbscam instead of mastercam, i get to learn alot of stuff all over
    May 2004
    4519
    I was speaking inefficiency in machining time, not tool life. Sorry.
    Jul 2012
    ya i mean that is a bit of a time waster, but im a small shop with a new to me older mill so anything i can do to squeeze more life out of tools the better, max i can run is 8000rpm and based on my math..which is most likely wrong,
    800SFPM on a 1/2" solid carbide endmill (was coated and is a regrind)
    .004IPT
    0.0625" DOC
    .2 step over
    6095 RPM
    121.9IPM
    that sound correct? Im so used to haas and having programs wrote already and using wips so its all pretty new to me doing the whole shabang!
    May 2004
    4519
    Can your older mill get 121 IPM? Might want to do a test if not sure.
    Jul 2012
    lol ya man, its old but not THAT old... 1991 cincinnati sabre 750, 450ipm rapids, i ran that program at 137.5ipm and works great!
    that was at 6875spindle rpm, im not sure what this carbide tool can handle but at that doc/rpm/feed rate it hardly made any noise so im thinking i can go a bit faster with a bigger doc (not that i needed more doc since i was only doing 1 pass.
    Aug 2006
    138
    Gibbs does do trochoidal tool paths. Look under Plug-ins>HSM. If you do a lot of pockets look in to VoluMill. I had the demo and it's pretty cool. You do need a fast controller/spindle/machine. I was playing with an Enshu bed mill with a 15M and it could barley keep up with Volumill code.
    Jul 2012
    I purchased volumill already, im pretty glad i chose gibbscam over mastercam so far.
    using volumill for facing
    and my first part made with gibbscam and my new (old) first mill. yea yea, i know...i had no holders so i couldn't chamfer the razor sharp edges, good thing i have a tumbler.
    15362
    txcncman
    Gibbs has had trochoidal milling for many years, it's the most efficient way to remove a lot of metal fast,add volumill & you can go even faster, & smoother
    Mactec54
    Jul 2012
    i have gibbs and volumill, both work great even for my old machine. removing material fast isnt what im after, its extending tool life while removing material faster...the tool life for me is a huge advantage over quicker machine cycles.
    May 2004
    4519
    txcncman
    Thanks. You might need to tell me one more time. Now, what was the original question?
  1. 2 gibbscam needs in NC
    By BILL WRIGHT CCR in forum Employment Opportunity
    Last Post: 11-11-2011, 10:17 PM
  2. Learning GibbsCam
    By 1QWK96GT in forum GibbsCAM
    Last Post: 02-21-2011, 11:48 PM
  3. Gibbscam
    By ramegut in forum Uncategorised CAM Discussion
    Last Post: 09-29-2009, 10:01 PM
  4. GibbsCAM
    By MagTDK in forum Uncategorised CAM Discussion
    Last Post: 09-24-2006, 06:57 PM
  5. Need some guidance to accomplish my goal....
    By DENALI in forum DIY CNC Router Table Machines
    Last Post: 04-27-2006, 09:52 AM
