586,108 active members*
3,112 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma LB15 Chuck Dwell Problem
    Jul 2012
    I have an Okuma LB15 lathe using a Sutton collet chuck. During the bar feed there is a long dwell (5-7 sec.) just after the collet opens and just after the collet closes. I have block deleted all dwells in the bar feed program, but the dwell doesn't change. Is there an optional parameter that I need to be changing or something? I have attached the main program as well as the sub-program (OAUTO).
    Attached Files Attached Files
    Jul 2012
    Never mind.
    Optional Parameter (Word) 8 & 9.
  1. Okuma LB15 OSP 5000L
    By CNCAndy in forum Mastercam
    Last Post: 01-23-2022, 08:09 PM
  2. okuma LB15
    By NJC in forum Okuma
    Last Post: 04-11-2013, 05:40 AM
  3. Okuma LB15 spindle motor problem
    By JINX222 in forum Okuma
    Last Post: 03-20-2012, 06:07 PM
  4. okuma LB15 help
    By cbrannam in forum Okuma
    Last Post: 10-09-2011, 12:45 PM
  5. Okuma lb15
    By firepoker1965 in forum Okuma
    Last Post: 09-23-2009, 02:01 PM
