How do you delete all chains in the chain manager dialog, when there are a lot of them. Im using X6. It seems you can only select/delete one item at a time?
thanks
thanks
R-click inside that dialog box
- & select the Re-chain all and then select your required chains
or
L-click on the top chain in the dialog box
- scroll to the last chain ( using the side scrollbar )
- hold down the shift key & L-click the last chain
- keep cursor in the dialog box, push delete
holding down the :-
- Shift key allows all items between the L-clicked items to be selected
- Control key & L-click is when you want to select ( & add ) individual items to your selection/s
Another useful shortcut when in the graphics display is:-
Shift key down when selecting a wireframe entity (L-click) forces a chain selection
ie you want to alter attrubutes on all items that connect to 1 particular entity
or you want to know if it is a chaining profile ( trimmed correctly -no breaks etc)
OK,SMan I'll give it a try.
thanks
