Is it possible to manually modify the generated tool path curve geometry inside of a MadCAM working session?
Scenario: I am cutting a new neck design and prefer to perform my final Z-level pass running along the X-axis (parallel to my neck centerline), and due to the shallow edge taper I am getting many tool lifts/repositions to cut areas that can easily be cleaned with my first sanding pass. The attached image is a close-up of my tool path with a 0.004" offset between passes
I am using MadCAM 4.3 basic with Rhino 4.0 SR9
I have played with the variable values, and some values work great for cerain regions but cause other regions to increase the number of lifts.
I'm sure I could spend time digging thru the G-code, but editing the path geometry seems like a more robust and efficient means if it's possible to do so
all the best,
R
