586,058 active members*
4,691 visitors online*
Results 1 to 16 of 16
    Jul 2012
    5
    Question Activate G54-G59 on Fanuc 21i-TA
    Hello, I have a cnc ROMI, with the controller Fanuc 21i-TA, and the manual says it has a 'Work' page, where is the G54, G55, etc, but when I press Offset, appears only 'Work Shift' softkey, and where it was to have the 'Work' is empty, someone could tell me how to activate this page? I work with pieces that makes in two phases in same jaw, so it's very complicated to use two tool offset for each tool, I would use the G54 and G55.
    Thanks.
    Jan 2011
    350
    PM sent.
    Oct 2010
    If you go onto the offsett page and press the softkey at the right of the screen, It should bring up other options. It´s been a while since i used one but i ithink it is around there somewhere or if not when you go onto the workshift page press the softkey on the right of the screen and see what options come up I use a fanuc O1T now mostly as well as okuma and when i press work it comes up straight away.
    Jul 2012
    5
    I tried this, but dont have the Work page, i heard its an optional...
    Thanks anyways
    Aug 2011
    2517
    yes, G54-G59 is an option, very easily enabled with the correct info.... which of course can't be posted here publicly
    Jan 2014
    Re: Activate G54-G59 on Fanuc 21i-TA
    Hey guys, could someone please pm me how to activate this option [that was purchased with the machine] It's a Hardinge Cobra42 with the Fanuc 21-T control. Tired of reseting all of tools for any new z work piece offset. Thanks in advance
    Hi all,
    I'm in a bind. My Okuma Howa Act-4 has a gremlin and is down. I need to finish a sizzling hot job and am switching to
    another lathe now and of course it doesn't have the g54-g59 activated. Could someone please share how to activate that
    option? Many thanks in advance.
    -Chris
    Apr 2009
    1379
    That is a Fanuc option. I can send the info by private message.
    May 2005
    I have a '97 Clausing Storm 110 and need to activate G54 as well. Same parameter changes, I assume? Fanuc 21i-T controller
    Feb 2018
    23
    Could you pm me the info please?
    - - - Updated - - -
    could you pm me the info please??
    Thank you
    Oct 2020
    I’m having the same issue with the same machine, could some one PM me the info please,
    Jan 2021
    Hi all. i I bought a Cincinnati hawk200 with the Fanuc 21i-T controller and there are no such options (G54-59)
    Who will help with this problem?
    Mar 2012
    109
    also looking for help via DM - Fanuc 21-T
    Apr 2009
    1379
    pm sent.
    Please you can send me ?
    Jun 2023
    hi i know it has been a while but was wondering if you would be willing to impart some knowledge via pm on this subject matter?? I have been trying to figure out how to unlock the g54-59 on the fanuc 21-t.
  1. Activate G54
    By KJ11 in forum Mori Seiki lathes
    Last Post: 07-16-2019, 08:49 AM
  2. help me to activate G5 fanuc function
    By ceramdent in forum Fanuc
    Last Post: 01-04-2012, 07:21 AM
  3. How do I activate the HPCC???
    By jsmith2232 in forum Mori Seiki Mills
    Last Post: 02-24-2011, 04:39 PM
  4. Replies: 2
    Last Post: 01-25-2010, 05:14 PM
