Originally Posted by
theremin
There isn't any support on the ballscrew on the Z axis, but if all the bearing blocks are tight, the ball screw shouldn't have any measurable lateral force on it. The rails and linear bearings take all of that stress, and the rails are bolted securely to the axis back plate.
With loose bearing blocks, as seems to be the case on your machine right now, all of that changes. If the ballscrew were supported at both ends, that might reduce the play that you are seeing, but it wouldn't be doing the ballscrew any good having that unplanned for lateral force acting on it.
Dave
