586,075 active members*
3,678 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Dremel/RotoZip bits in Porter Cable 690 router with 1/8" chuck bushing?
    Feb 2008
    263
    Is it safe to use 1/8" shank Dremel/RotoZip bits in Porter Cable 690 router using chuck bushing like the one in Router Shank Reduction Bushings - Toolstoday.com - Industrial Quality Carbide Tipped Router Bits ? I need a 1/8" router bit with 1/8" shank for cutting out parts from wood boards or plywood sheets. 1/8" router bits with 1/4" shanks aren't long enough.
    Apr 2009
    5516
    Quote Originally Posted by jeffmorris View Post
    I've used the Amana bushings with success, though it's better to get the PreciseBits collets and collet nut.
    Aug 2011
    999
    I tried to use roto zip bits (upcut as well as "sabre-cut" downcut bits) and they dulled in no time. Cheap but almost useless.
    Assuming you have the proper collet:
    If you need to have extra long reach try HTC Very reasonable price but at that length even carbide will flex and limit cut depth and/or feed rate.
  1. Quick Change Router Chuck for Porter Cable 690/890 Routers?
    By jeffmorris in forum DIY CNC Router Table Machines
    Last Post: 07-05-2012, 10:27 PM
  2. Mach3 and Porter-cable router "spindles"
    By SpacedCowboy in forum Mach Software (ArtSoft software)
    Last Post: 02-13-2012, 01:25 AM
  3. Dewalt DWP611 and Porter Cable 450 "Compact" Routers + Questions
    By Scheer in forum DIY CNC Router Table Machines
    Last Post: 12-27-2010, 12:24 PM
  4. Porter Cable Drill Chuck Mod.. Any ideas?
    By Gene-Yo in forum DIY CNC Router Table Machines
    Last Post: 11-13-2006, 07:14 PM
  5. Using Dremel 3/16" Bits In My MaxNC
    By roys29 in forum Benchtop Machines
    Last Post: 12-12-2005, 03:59 PM
