the alarm is 1066 atc not in zero position, the arm of the tool changer is stuck between the spindle and the carousel. Is there a m-code to try or do i have to remove it manually. Thanks alot
You have to rotate the arm manually from motor by releasing the motor brake.
you should try this
Automatic Tool Changers and Tool magazines with characteristics
