Well, I just assembled the first five of my new BT15 ATC spindle.
Specifications:
- Tool Holder size ISO15 or BT15 with 15deg retention knob.
- Body - 60mm OD.
- Bolt pattern - 8 x M4 on 70mm DIA
- Flange - 80mm OD.
- RPM - 6,000, 8,000, 12,000, 15,000.
- Petal-Clamp, black nitride coated.
- BelleVille Disc Springs 225lbs to 350lbs (as required).
- Run-Out - 0.0005in or better (ISO specifications allow 0.0008in).
- User replaceable bearings.
- Weight - 2KG (4.5lbs)
I did some checking and this is what I came up with, BT30 price is $2870.00 plus shipping, BT25 price is $2384.00 plus shipping, BT20 price is $1842.00 plus shipping, I couldn't find anything for a BT15 so I guess I'm the first to offer it.
If I follow this convention the BT15 would come in around $1375.00 plus shipping so I'm thinking $800.00 plus shipping is a reasonable price (excluding the 15,000RPM due to cost of ceramic bearings).
This is something I will be producing and selling myself so it should be available for quite some time.
I've attached pictures of one spindle and a handful of the petal clamps so you can see what's inside and one showing the tool holders.
Added a picture of an assembled spindle, I didn't shorten this shaft because the purchaser may require a 1.000in belt instead of the 0.375in belt.
Added a picture of a sherline mill head with ISO15 ATC Spindle conversion kit installed and another spindle cartridge with dual pulleys.
