586,103 active members*
3,514 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Line or cross hair laser alignment
Results 1 to 8 of 8
    Jan 2012
    55
    does anyone know of a place I can purchase a line or crosshair alignment pointer that I can easily mount in the spindle of my CNC router? I am looking for something that is battery operated and cableless. I found some but they are a little pricey. I was hoping to find something under $100.00 if possible
    Dale
    Oct 2011
    Check out deal extreme, aixiz.net or ebay for a laser module and lens. Btw you can tape a 3v battery some modules and it seems to work fine.
    Jan 2006
    2985
    use-enco.com
    shars.com
    Apr 2005
    1268
    I purchased an add laser light for a circular saw from Harbor Freight and disassembled it to the needed components. I took out the line lens and it works fine for a rough indication. Got me where I needed to go for less than 10 bucks.
    Not the best but, oh well, what can I say.
    B
    billyjack
    Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
    Sep 2012
    Quote Originally Posted by dkrenfrow View Post
    Dale
    It would be fine to get an alignment laser from a specialized laser supplier. Usually you can get a cheaper laser from China. Good luck, guy!
    Oct 2012
    120
    Wondering if you got your answer
    I just bought a Cross Hair laser last night. I think it was around 12 buck all in.
    No clue how I am going to mount it, but I thought it would make for an itneresting puzzle
    Nov 2007
    2466
    [ame="http://www.amazon.com/AixiZ-Aluminum-Mount-Diameter-Modules/dp/B005FSWU5U/ref=pd_sim_sbs_misc_4"]Amazon.com: AixiZ Aluminum Mount for 12mm Diameter Laser Modules: Everything Else[/ame]
    [ame=http://www.amazon.com/Aixiz-405nm-cross-laser-module/dp/B005Z50C2G/ref=reg_hu-rd_add_1_dp]Amazon.com: Aixiz 405nm 5mw cross laser module: Everything Else[/ame]
    James McGrew CAMaster 508 ATC
    www.mcgrewwoodwork.com http://dropc.am/p/EJaKyl
    Oct 2012
    120
    thanks
    I already have one, but thank you.
  1. Laser.Tech's Guide to CO2 Alignment
    By Laser.Tech in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-10-2015, 03:58 AM
  2. Laser spindle alignment?
    By cgallery in forum DIY CNC Router Table Machines
    Last Post: 12-22-2014, 01:01 AM
  3. newbie needs help with laser alignment
    By dominic gailgan in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-10-2012, 09:02 PM
  4. Laser Beam alignment
    By graver1 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-24-2011, 05:48 AM
  5. invisable cross hair...almost
    By ajl6549 in forum Mastercam
    Last Post: 06-14-2006, 09:10 PM
