586,121 active members*
3,243 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Pressing shaft out of electric motor rotor?
    Aug 2005
    828
    Any one ever press out the shaft from the rotor of a electric motor? I'm trying with a 20 ton press no luck. This is a 3 phase 3 hp motor the shaft is about 1.25" diameter were the rotor is. I already bent it a little so no stopping now. I hope I don't need a 100 ton to get it out....
    Dennis
    Nov 2009
    59
    Press Shaft
    You need to make sure you are pressing in the same direction the shaft was installed in or you will never get it to move.
    As the original shaft is pressed in the iron plates roll in the direction the shaft is pushed in.
    Very important to push the right direction
    My 2 Cents worth
  1. Electric motor rotor balancer?
    By DennisCNC in forum CNC Machine Related Electronics
    Last Post: 07-18-2019, 02:22 PM
  2. Step Motor Rotor Inertia Units
    By mcArch in forum Stepper Motors / Drives
    Last Post: 06-04-2008, 03:29 PM
  3. Boring out ac motor rotor?
    Last Post: 04-01-2008, 12:41 PM
  4. Looking for a Coupling for 1/2" motor shaft to KR33 6mm shaft
    By DonW in forum DIY CNC Router Table Machines
    Last Post: 03-17-2008, 09:58 PM
  5. Remagnetizing stepper motor rotor
    By Konstantin in forum CNC Machine Related Electronics
    Last Post: 04-11-2004, 02:47 PM
